Okay, well let me start of by saying that the quality of this product is not nearly as good as some of the previous alarms I've installed (mostly DEI alarms), but I pretty much expected this! I'm not really worried, so long as it works!
Their installation instructions are pretty lame (and pretty generic, looks like they use the same instructions for their full line of systems), good thing I have a tad bit of experience under my belt.
The remote start activation sequence is quite simple
Code:
While the car is still running:
-pull the hand brake
-press the brake pedal 2 times
(alarm will confirm with 2 flashes/chirps & doors will unlock)
-Remove key (car will stay running)
-Exit the car & close the door(s) within 30 second
The system will disengage the remote start if a door
is opened at any time before remote starting. This can
be prevented if the car is remote started before opening
the door, then manually shutting off the car (via remote)
after the door(s) have been closed.
This particular system from this place only consists of 3 harnesses to wire, but only a few wires for me to hook up in the Accord:
Needed wires willl be in BOLD, unnecessary wires will be in ITALIC and optional wires will be left in PLAIN.
6 PIN HEAVY GAUGE HARNESS:
Code:
*Starter output (+)
*Heater/Accessory output (+)
*12 Volt Input (+)30A
*Selectable output (+)
(for second Starter, Ignition or Accessory)
14 PIN HARNESS
Code:
*Re-arm (-)250ma
*Trunk Release (-)250ma
*Dis-arm (-)250ma
*Ground While Running output (-)
*Siren output (+)250ma
*Parking Brake input (-)
*Door Pin input (+)
*Hood Pin Switch (-)
*Door Pin input (-)
*System Ground input (-)
*Brake light Switch input (+)
*Tach. Input (-)
*Diesel Wait-to-Start input (+ or -)
3 PIN HARNESS (LOCKS)
I'm installing aftermarket actuators, since the coupes didn't have the auto locks as an option. I will also be installing manual lock/unlock switches inside the car, for manual operation.
Code:
*Door Lock output (-)250ma
*12v output (+)250ma
*Door Unlock output (-)250ma
ANTENNA 4 PIN CONNECTOR
No need for wiring here .
