I got another small project done,I decided to just mount the aux back up lights fixed for now. I originally built them to be motorized and swing down,but I may just work on that mechanism later. I just don't the time right now,and I really needed to be able to see where i was going. these are 55 watts each side,so they are pretty bright. you can't see them at all ground level. so they are well hidden.
one of my factory backup lights looks brighter then the other because I have the wrong bulb in it.
I ran the power off of these from the 40 amp bus that i have running to the back. they are switched on by a relay from the factory lights. If I can find a small time delay module,I'll wire a second relay so they all come on when you open the hatch,for a predetermined amount of time.
