i was just browsing and came across this stereo:
Features:
* Supports MP3 & WMA playback from CD-R, CD-RW data discs or USB⁄SD⁄MMC devices.
* Displays MP3 file & folder name along with file & folder search facility
* SD ⁄ MMC FLASH Memory Card slot supports WMA & MP3 file playback
* USB 1.1 port supports WMA & MP3 file playback for most USB FLASH drives
* MP3 ID3 tag supported and displays Music, Artist & Album titles
* Can record from line-in, CD or Tuner to USB FLASH drive or SD⁄MMC memory card
* DOT Matrix type LCD Display with Blue LED backlight
* Audio Digital Signal Processor (ADSP) supports Classic, POP, Rock & Flat modes
* 4x 35W RMS MAX Class AB Power Amplifier with sturdy die-cast heatsink
* Stereo line in and out ports (front and rear) for further expansion to another audio source and or audio power amp⁄s
* Seek and preset scan with 30 station presets (18 FM & 12 AM) with one touch station memory
* Pause, mute, bass, treble, balance & fader controls
* Play modes include Intro scan (10s), random and repeat play
* Industry standard ISO-DIN mounting with flip down detachable panel for anti-theft security
* Tuning Modes: Manual, Seek and Preset
* AM Frequency Range: 522KHz ~ 1710KHz
* AM Tuning Steps: 9KHz
* AM Preset Memories: 12 in 2 bands (AM1 & AM2)
* AM Sensitivity: 30dBuV
* FM Tuning Range: 88.0MHz ~ 108MHz
* FM Tuning Steps: 100KHz
* FM Preset Memories: 18 in 3 bands (FM1, FM2 & FM3)
* FM Sensitivity: 15dB
* FM Stereo Separation: 28dB
* Frequency Range: 20Hz ~ 20KHz
* Output (Po max): 4x 35W MAX into 4 Ohms @ 14.4V
* Amp Type: Bipolar Class AB
* Speaker Load Impedance: 4 Ohms (4~ 8 Ohms allowable)
* Pre-out Voltage & Impedance: 2V @ 10K
* Display Type: Dot matrix type LCD with blue LED backlight
* Face Type: Flip down with detachable front panel
* Operating Angle: Maximum of 30 Deg. (horizontal plane)
* Voltage: 10.8 ~ 15.1VDC negative ground
* Current: =< 10A DC
* Dimensions (W x D x H): 178mm x 175mm x 50mm
* Remote Dimensions (W x D x H): 95mm x 52mm x 8mm
* Processor: Samsung Audio MCU with SAM88RC core, 16K ROM, 512Byte RAM, onboard PLL, 8-bit A⁄D, LCD Controller Etc.
* Remote Control: Card Type 20 button IR remote
* Package Includes: L8900 Car AM⁄FM⁄CD⁄MP3 Player with 10A blade fuse installed; Detachable Face; Hard Plastic Face Case; Wiring Harness; ISO-DIN Sleeve; Trim Ring; 2x unit Removal Tools; USB Extension Cable; Installation Guide & remote control
* Media Supported: CD, CD-R & CD-RW
* DAC: Sigma-delta stereo DAC
* Over Sampling: 4x digital filter.
* Digital de-emphasis: 32kHz & 44.1kHz
* Sub Code Data Processing: Q data CRC check, Q data register installed.
* File System Support: ISO9660, Romeo, Joliet, UDF
* Multisession Disc Play: supported
* Audio L.P.F, EFM data demodulation
* Frame sync detection, protection & insertion.
* MP3 Record: Records from CD, Tuner & Line-in to SD ⁄ MMC card slot @ 128kbps or to USB port @ 40kbps
* Codec Support: MP3, WMA
* MP3 Bit Rate: 8~320kbps or VBR
* WMA Bit Rate: 48~192kbps, VBR
* WMA Format: WMA v2, v3, v7, v8
* ID3⁄WMA Tag: ID3 v1.0, 1.1, 2.3, 2.4
* ID3⁄WMA Tag Max. Length: 40 bytes
* ID3⁄WMA Tag Max. Data: Title, Artist, Album, Year
* SD⁄USB File System Support: FAT16, FAT32
* SD⁄USB Max. Directories: 5000
* SD⁄USB Max. Folders⁄Directory: No limit
* SD⁄USB Max. File⁄Folder: No limit
* SD⁄USB Max. File⁄Disc: 10000
* CD⁄Mp3 Max. Directories: 256
* CD⁄Mp3 Max. Folders⁄Directory: No limit
* CD⁄Mp3 Max. File⁄Folder: No limit
* CD⁄Mp3 Max. File⁄Disc: 896
* Disc Random Play: all files
* Repeat Play: File
* Max File Name Length: 40 bytes
* Max Folder Name Length: 40 bytes
* Warranty: 1 Year return to Dick Smith Electronics
oh yeah, it's for sale @ $150
i wouldnt have much of a clue what the above really means, but im looking for something that plays SD cards & flash drives, I don't really care if its not loud enough to be heard 1km away, but i want something that can make some decent bass.... is $150 a alright price? can someone give the audio noob some tips?
