So i'm thinking that since I have every thing apart on my car, and I diden't install the B20 yet, should I do the obd1 conversion? I would rather do it now then later. I know some of you have comleted it any tips suggestions?
no tips and tricks for it from me. but i say go for it. like you said, everything is already out, could make things a bit easier. however, on the flip side, if you put it in first, you can make sure it's running tip-top first so you don't have to try to figure out if it's the engine or the obd-1 conversion if something isn't running right. however, unless you got the original ecu and stuff, you have to hack up the wiring and ecu combo anyway so you might as well go obd-1. go for it! :)
Go with OBD1 from the beginning and you will save yourself a lot of trouble. You'll end up converting sooner or later.
I got my ODB-0 to ODB-1 here http://www.xenocron.com/products.php?page=convharness then i switched like five wires to make work on my accord then i made a whole new engine harness for my b20a so when i put it in it all plug and play.thegreatdane did you hook up the knock sensor on your PO6 Ecu?
Nope I'm not using any knock sensor, I have doubts about their effectivity..
Which one did you get? the Integra one? and can you show me what wires had to be changed, or what you did to make it plug and play?Originally Posted by TWOLOUDNPROUD
This oneOriginally Posted by EX-ileAccord
Convert your 1988-1991 civic/crx and 1990-1991 Integra to run any manual OBD1 1992-1995 ecu. Requirements: All civic/crx models must either be a SI or HF or a MPFI(Multi Point Fuel Injection) converted car. DX and Standard models that are DPFI (Dual Point Fuel Injection) must be converted to MPFI for this conversion to work properly. This conversion is primarily made for a 5 speed chassis. You will need an OBD1 ecu, distributor and a 4 wire O2 sensor.
All Harnesses come with detailed instructions for an easy installation. Also included with the harness is a quick disconnect connector that will allow you to feed the sensor wires through the firewall easily. All sensor wires are color coordinated for an easy installation.
Sweet. I just won a b16 intake manifold on ebay for 30 bux :D and got a lead on a b18 distributer, now to peice it all toghther
