i have this odd problem here, these 2 things are in the way of each other when i try bolting the gearbox to the engine :(
how do i fix this? what are they for? can i just chop them off?
it's a b2k5 gearbox on a black top if that info helps any
just pull one off
There dowell pins. They help you line it up when you bolt it to the engine.
there should be one on each side
not on the same holeOriginally Posted by ghettogeddy
Yep, pull one out and put it in the other side. Looks like they're both in the same side of the tranny / engine.
all done, thanks peoples :) :thumbup:
looks good.
your welcome godzilla
