Any idea, or a list of things to check? I already check the fuses inside the car, they all look fine.
the headlight motor probly died get another one
This is most likely the case. If you want to check the fuse they are in the under-hood box and are labeled L and R "RETRACTOR UNIT", or something like that.Originally Posted by 1ajs
I checked the underhood fuses today, and they're both good. Just to be sure I swapped the fuess, and it's still the driver's side that's being stupid. So is there a way to test the motor?
the motors hardly ever go out on these cars, mayube the switch is broken?>
Not a switch if only one isn't working, and yes these motors can go out. Did you try turning it manually? If you remove the 2 screws near the top and pull it off, you can check the condition of the brushes. You may be able to bend their arms in a bit if there is still graphite left.Originally Posted by A18A
if you need a motor let me know, or if anyone needs some parts let me know im junking my parts car this week so free parts just pay shipping, most stuff is gone but let me know what you need as long as its not too hard to take out. If your in Ontario or near Toronto you can come and grab what you need too
