Results 1 to 15 of 15
Thread: Weird turbo Q
    1988 Honda Accord LX
    Ventura
    Weird turbo Q
    i have a extra draw-through turbo system for my VW .. i was wondering can i use a turbo header to mount it (its a t3/t4 flange and my VW motor is a 2110cc so it will have enough fuel) ?? or am i just carzy
    Ps.. i want to stay carbed just ideas flying through my head .. I konw there will be some issues but im a good mechanic and have a great understanding of the internal combustion and turbo systems
    I dont Drive Crazy .. Sprited driving is what I call it.
    Re: Weird turbo Q
    if i remember corectly there was one guy who was running a pull threw turbo/carbed setup... if i also remember right the car didnt last to long, he ended up blowing the rings out of it.. but search around i know that atleast that thread is on here someplace, if i run across it i will post it up
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    Re: Weird turbo Q
    post pics of what you got. I'd like to see how it looks.
    Ventura
    Re: Weird turbo Q
    it looks like a turbo with a carb right in front..
    .. not my car but its the same setup.. i have a lot of extra shit laying around, because a VW always breaks something
    2ndGenGuy
    Guest
    Re: Weird turbo Q
    I don't see why you couldn't do something like that on the Accord. Just have to run your own charge piping to the intake manifold, cut and weld some kind of flange that bolts where the old carb went. Not sure how much room you would have in front of the engine to fit the carb though.
    Nov 2002
    Ridin Dirty in New York
    Re: Weird turbo Q
    go blowthrough, its a much better setup
    theres some old info on it, i still havent found the thread of the a20 with it though, but i know im not crazy...i know i have seen it...
    ok i found the thread i was looking for before... i guess i looked this thread over when i was still a noob so lol its not a a20a3, its a cb3 accord with a carbed F20a3 engine but still about the same concept, anyways heres the thread
    https://www.3geez.com/forum/showthread.php?t=46047
    Ventura
    Re: Weird turbo Q
    so i just mocked up the turbo and carb it will fit just need to move the fan, or get a slim one.. hell i give it a try as soon as i rebuild the motor. no point of having a boosted 170K motor, your just asking for trouble.. thanks for the info ..
    Re: Weird turbo Q
    yep you are crazy but aint we all? lol
    I dont see how that would last without timing controls, on that I would guess something like a crank signal ignition controller, programable, and since it is draw through.. a throttle position sensor. Boost controller too, wastegate, and what about the exhaust temp.. there are just so many things to consider on that set up. VW need reliefs in the pistons when you use forced induction too. I think blow through would be more reliable or say... safer.. but it sure does look pretty.
    I wouldn't go messing around with the fan, that is the life support on a bug. it has to be shrouded and keep airflow on those cylinders.
    I also think some cooling fins on the header pipes up to the turbo would be a good thing, or some sort of intercooler set up there.
    What is the car going to be used for, just a drag car you can probably make short cuts but you couldnt hot lap, and plan on a rebuild pretty often.
    Ventura
    Re: Weird turbo Q
    ya thats not my bug its just the same setup .. and i been running 18psi on my bug for about 2years with a drawthrough and street driven .. and about being safer thats up in the air?? Also i know about EGT and A/F ..
    Re: Weird turbo Q
    Quote Originally Posted by koss007 View Post
    sounds bad ass
    Ventura
    Re: Weird turbo Q
    it will be my winter project .. once i start .. i dont see there being too much issues .. but i have been wrong before .. i know ill be rebuilding the motor on DEC. 14
    Ventura
    Re: Weird turbo Q
    so .. doing some research these past few weeks .. and a blowthrough is a better idea. + u get to use a BOV and intercooler . my parts are starting to arrive, i got my pistons, rods, rings, and oilpump today .. waiting on bearings and gaskets.. I cant wait
    cygnus x-1's Avatar
    Chicago area
    Re: Weird turbo Q
    Interesting project. And a tuning adventure for sure. For timing the easiest thing would be to just run static advance across the board. Maybe 12-14 degrees BTDC. Won't be very efficient but it would work. Or you could disable the vacuum advance and just run the centrifugal advance.
    I really want to see this running.
    C|
    Vanilla Sky's Avatar
    1999 Penalty Box
    Re: Weird turbo Q
    DCOE carbs?
    /subscribed
  1. Turbo 3G role call... Paging turbo'ed guys
    By AccordEpicenter in forum Forced Induction
    Last Post: 06-07-2011, 11:26 AM
  2. for the turbo guys/wana go turbo/dream of going turbo
    By ZackieDarko in forum Performance
    Last Post: 01-14-2007, 11:22 PM
  3. People with turbo 3G accords and turbo 3g projects
    By AccordEpicenter in forum Classic Honda Community Chat
    Last Post: 11-08-2006, 06:30 PM
  4. Replies: 8
    Last Post: 02-11-2004, 05:30 PM
