roodoo2
Ok, I drove THIS one to work today. Wow is all I can say once again. I was kinda pissed because traffic was so tight this morning so I couldn't do any full out running anywhere. I did though get to a point where I was on flat ground creeping in 5th gear at 40 mph, and I gave it just a little mash not even flooring it and it picked up to 75 in a matter of about two seconds without even downshifting. If you had driven my DX before that you would realize just how amazing that was. I am loving this carb, and even though it was tuned to a more modified engine I think it is pretty close to where it needs to be. I was on the interstate and just barely breathing on the gas pedal, MPG will improve I believe.
I have the jetting numbers wrote down so if any of you have 38 DGS you may want to try this set up. I will edit them in later unless you still have them Cygnus x1, I took it apart but I didn't change any thing, just took them all out and jotted them down at home. No leaks so far ! I am going to fix the pvc set up today, I will take some pics, I use a mopar v8 heater bypass hose to house the valve and run it around to the back, it worked pretty well on my other car.
