Don't post in this thread - just vote.
Turabaka
1988 Honda Accord Hatchback DX
Engine Specifications:
- 38 Weber Carb
- Delta 272 cam
- ported intake manifold
- MSD blaster 2 coil
- Accell super stock 8mm wires
- Optima red top starting battery
Fuel & Tuning:
- Holley blue fuel pump with regulator set to 3psi
Exhaust:
- Pacesetter header
- 2.25 inch mandrel bent exhaust
- Magnaflow cat and muffler
Drivetrain:
- Pacesetter short throw shifter
Weight reduction & transfer:
- stripped carpet and sound deadening
- full vac removal
Suspension, wheels & tires:
- Tokico blue shocks
- Sprint springs
- Acura Vigor rear sway bar
- 2g prelude front upper control arms
- SE-i disc brake setup
- 215/45-16 Falken Azenis tires
Interior:
- stripped carpet
- sunpro water temp, volt, and oil psi gauges
- indiglo gauges for tach, speedo, and temp
Exterior:
- 20% tint all around
[/quote]
