Page 1 of 4 1234 LastLast
Results 1 to 25 of 85
Thread: Clearcoat over sharpie ink??
    LXi User SZfiftyfour's Avatar
    '82 Accord DX Sdn
    Ocala, FL.
    Looking for some advice on what to use.
    I did this valve cover back when I had a 3g. It's been sitting in the closet a while now unfinished and I don't see me getting another 3g in the near future. So, once it's cleared I'm probably going to sell it here on 3geez.
    Basically I'm worried that the paint will melt/run the alcohol-based ink. I've already tested engine enamel clear(on something else), which didn't affect the ink too badly, but was not really 'clear' either. Anyone had good/bad exp with spraycan clearcoats?
    VC Pics:
    Overview
    Front 1
    Front 2
    Front 3
    Dizz side
    top1
    top2
    back
    back
    LXi User CzEcHy's Avatar
    Jul 2008
    89 Accord LXI
    Gulf Breeze, Florida
    Re: Clearcoat over sharpie ink??
    Not really useful to helping you out but..
    NICE artwork.
    WOAH that is so badass. Man I love the DOMO and the 3GEEZ on there!
    The only thing I could suggest, is get some scrap metal and draw some stuff with that same kind of marker. Then test it out by hitting it with some clearcoat... and see what happens...
    Vanilla Sky's Avatar
    1999 Penalty Box
    Have you tried your hand at airbrushing?
    I'd think anything solvent based will run that ink. Everything that I can think of won't stand up to engine heat. I guess you'll have to experiment.
    '82 Accord DX Sdn
    Ocala, FL.
    thanks guys, its all freehanded, but some stuff is influenced by other sharpie art on the internetz.
    Those japanese kanji mean Honda, for anyone wondering.
    I've tested that 500deg engine clearcoat but it wasn't as clear as i'd like it to be. I suppose i'll just have to get a bunch of different clearcoat types and test em all.
    Resin will stand up to the heat, but that crap is too messy.
    I haven't tried airbrushing yet. always wanted to though. I even have a model airbrush kit i never opened.
    Regular clearcoat will hold up just fine. Your engine won't get above 180-200 degrees anyways. If it does, you're in trouble!!! My whole engine is painted with regular old automotive paint...
    1999 Penalty Box
    Come to think about it, there's a Testors clear that's pretty good. Might want to check it out.
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Exhaust temps are higher than that!
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    that stuff eventually yellows and flakes after u apply heat like that
    '82 Accord DX Sdn
    Ocala, FL.
    edit: ^^ hhmmm... wouldn't want that.
    I just read the instructions on the 500deg clear; says the color coat needs to be wet still. 'When all else fails' i guess.
    I remember that testors stuff, from back in the day when I was into models lol. I'm gonna try that and the krylon stuff.
    Well don't route your custom headers up over your valve cover and you should be fine. My block has yet to peel, even near the exhaust system.
    1999 Penalty Box
    You could always go over it with paint. I'm not sure how paint would stick, but I'm sure it would do OK. Clear over that with the high temp stuff and you should be fine.
    LX User Lil Mike's Avatar
    Toronto, Ontario
    any clear coat should work fine i have a buddy who used regular rattle can paint and has never had a problem with peeling.
    thanks mkymonkey
    LXi User headbanger's Avatar
    Dec 2007
    1989 accord lxi
    waynesville,nc
    that is the most b-e-a- utiful valve cover I have ever seen.That should be hanging on a wall somewhere not hid under a car hood. nice work man.You might could take it an have it powder coated clear.That is what I would do then you know it wont peel or ruin the cover.
    It will be there forever.
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    holy crap that is awesome. If you decide to sell it I have first dibs on buying it! You heard it guys. DIBS!
    Ichiban's Avatar
    North of You.
    Your engine block is full of water. It shouldn't be much hotter than, well, water in it's liquid form.
    ICHIBAN!
    "Now, even more better!"
    Dec 2007
    1989 accord lxi
    waynesville,nc
    bid war lol
    Apr 2009
    1987 Accord Lx-i
    Gaffney, SC
    that is the sex
    SEi User codyJDM's Avatar
    Apr 2008
    '88 civic wagon
    SoCal
    So fucking sick!! Install it asap
    omg thats awesome
    LX User stezie's Avatar
    1988 Accord 2.0i 16V (B20A2)
    Co. Donegal, Ireland
    Quote Originally Posted by guyhatesmycar View Post
    But its pressurised water. Water will stay in its liquid form to a much higher temperature. Water has a much higher boiling point under pressure. thats why you should never open the radiator cap when engine is hot.. and for those of you that does, its steam every where and you will hear the water in the block boiling straight away.
    Hawt!
    '82 Accord DX Sdn
    Ocala, FL.
    Thanks for the comments guys.
    Picked up some Krylon crystal clear gloss [acrylic] yesterday, so I'm going to test that out. All the rustoleum enamel paints said not for use on surfaces that exceed 200deg.
    go to eastwood.com and look for their diamond clear, take some scrap metal draw some on it and test it. the diamond clear isn't cheap but if you want quality it's not going to be
    SEi User 86ccord's Avatar
    Middle Georgia USA
    well, if you use real clear coat, like the stuff i use when i paint a car, it will not crack and flake off..
    now for the ppl who do the hoods and the cars with sharpie. they just draw, and hit some clear coat over it. and its done..
    all cars were done with sharpie, then clear coat.
    check it.
    http://farm3.static.flickr.com/2434/...a99b424b_b.jpg
    http://www.doobybrain.com/wp-content...ardo-whole.jpg
    one day I'll return.
  1. Acrylic Enamel vs Basecoat/Clearcoat
    By Ichiban in forum Interior & Exterior Care
    Last Post: 06-06-2007, 02:17 PM
  2. Masking Tape on Clearcoat
    By bushbean in forum Interior & Exterior Care
    Last Post: 05-22-2007, 05:03 PM
  3. clearcoat?
    By pixiesfan78 in forum Interior & Exterior Care
    Last Post: 06-20-2004, 08:46 PM
