sup guys putting up some new pics of my car installed some new fog lights today and let me know what you think
what kinds of lamps are those?
You should take a picture of the light output on a wall or something. Take a picture during the day too.
I need these parts!
they are a h4 conversion projector lamps and ill take pics during the day still need to figure out how to put the switch under the dash didnt have enough if not ill sawder the wire to the headlights to turn them on but the first switch not the second
day time
Night shots:
fogs lights only.
fogs and headlights:
fogs look good.. should of went with hella or autopals for the headlights
whoa thats trippy
yeah thats how the lights look from the side if i took them from inside the car it would look normal and i will be upgrading to these HID in january and be getting new speakers but first i have to get the valve cover from daniel
http://cgi.ebay.com/ebaymotors/ws/eB...ht_3948wt_1165
I had those Ebay Projectors...IM telling you now you dont want to put HIDs on those. Your going to hate it and your going to get alot of flashing from other upcoming traffic. after a good year i started seening water inside the housing and Burning up my hid blub. i replaced em and its not cool spending 50 bucks for a set of Blubs everytime.
SO instead i spend the 60 bucks on hellas and i have a pretty good cutoff. I hated the Ebays for the reason you see on your pic. Looking like you walking into a ice cave. I would keep those for awhile. upgrade to the Autopal or hella E Codes Then get the HIDS.....
Just my o2 cents.
yeah true saw a lil bit of water in there and i was look at these headlamps are these the ones you talking about rendon??
http://cgi.ebay.com/ebaymotors/Hella...ht_3520wt_1165
or you know a website?? where i can find them cause the other ones cost like 130$$ just for the lamps
Yup those are the ones. Alittle spendy but well worth it.
alright ill buy them and are those the ones you have on your car?? got any pics?
E-Code's the way to go or Autopals.
I have the Hella's on mine.
https://www.3geez.com/forum/showthread.php?t=55885
No recent ones...but i have those.
Damn those are nice pico now I'm getting some for sure way better lighting than the projectors
For a little bit better cutoff/light scatter with using Hids, use some Hella or Cibie E codes. They are made for Euro driving and have a different cutoff pattern. Might be a little bit harder to come by, buit cost about the same as regular hellas, and usually have driving lights in the that you can wire up if you want.
~~NGK~~Silvania~~MSD~~Pioneer~~MSW~~Bosch~~DC Sports~~115WHP 116WTQ
i like the luminics ultra white bulbs thoses with the silverstar housings would look sweet
heres a compearson in the lumincs and silverstars
http://www.b15sentra.net/forums/showthread.php?t=125868
and heres some pics i took. the high beams are some phillps bulbs that were there when i got it..
http://tinypic.com/a/1ddue/2
there brighter then every other bulb ive used but not bright enough to get flashed and fliped off![]()
CAH those are sick i like the blue better i think its um ice berg blue isnt it??
http://cgi.ebay.com/ebaymotors/Hella...3dc10440c#shId
ok i been thinking is this the same as hella or is it a scam??
Shy, how did you wire those fogs? If you put them in the headlight circuit you're going to eventually have problems with the headlight switch, which is weakest point in the headlight circuit - you don't want to be putting any more watts through the switch than the regular headlights draw. A few years ago, I put in some higher-output bulbs and they seemed fine - I even checked the connectors to the bulbs, which is what I partially melted on an Audi I had - seemed ok. In about a month I lost the headlight switch.
Best thing is to put in a relay that controls the fogs. That's what Honda should have done with the headlights, but they didn't, so all the juice goes through the switch.
dont worry w261 i took them off since i been losing to much power and i had those fogs hooked up to a switch but i couldnt get the wire all the way inside car to put it in the dash so if i wanted to turn them on the switch was right next to the license plate and flipped the switch there and i had it hook up to the battery and a fuse to maintain the power flow so they wont drain the battery since i did it before i fogot to put the fuse on and it drained my old battery die haha and i didnt know how to install them until i read the wiring color and meaning so it took me about 2 hours to put them on.
but cant we add a relay for the headlights?? i seem to have an extra space for the relays since i only have like 3 on there one for the fuel,wipers,and last im guessing its for the windows...
Maybe this is the year I'll get around to putting fogs on my car. If I do, I'm going to put relays in for both the fog and headlamp circuits. Then, maybe, I can up the wattage on the headlight bulbs (have to see how the connectors take it).
I'd really like to put in 4 new little lights in the grill - two fogs and two driving lights.
cool if you want fogs you can take mine ill throw in the lamps and fuse that connects to the battery and the switch
