Went to replace the thermostat, and as usual one of the bolts snapped in the housing. So I pull the distributor, air cleaner piping etc. to get a straight shot at it. So I was able to finally drill through the bolt and figured I will tap it. But I decided to put a extractor in there to remove the bolt, but it broke, and I cannot drill through the hardened steel extractor piece that broke. So my option is to remove the housing which bolts to the head. But the only way to get to the bottom nut is to remove the EGR pipe. I really wanted to avoid this but this looks like I will have to get another housing at the pick your part. But I am worried about a 22 year old EGR pipe trying to break free from the exhaust manifold. Give any insite from those who may have done it. Remove the radiator to make more room to get at the large nut on the exhaust manifold? What size is that large nut? It's an 88 LXi.
