Results 1 to 19 of 19
Thread: low beam headlights 89 accord not working
    Jan 2010
    1989 Honda Accord SI 2L
    australia
    both headlights low beam not working accord 1989 si 2.0l , high beams do work put a new bulbs in , check fuses under the dash on the drivers side all are good ? what could be the problem? thanks
    Re: low beam headlights 89 accord not working
    Quote Originally Posted by accord1989 View Post
    are the relays ok
    Jan 2010
    australia
    what relays? how do i find them? thanks
    under the hood in the box next to the battery
    mine stopped working after replacing the multi function switch, I never went back in to diagnose.. maybe a plug?
    Jan 2010
    australia
    i checked the relays still good ! what else ?
    LX User LxAcc510's Avatar
    May 2008
    1989 Honda Accord LX
    Where they say Hella, CA
    you need new bulbs
    '89 LX 295,000 3/1/09 =D
    Jan 2010
    australia
    Quote Originally Posted by LxAcc510 View Post
    you need new bulbs
    i already installed new bulbs
    SE-i Sedan 5 spd
    Did you put in some extra-powerful headlight bulbs by any chance? The weakest part of the headlight circuit is the headlight switch, which is the first to go because of a high current draw. The usual failure mode of the switch is for the low beams to go. That's what I would bet it is. I assume both lows failed at the same time.
    Jan 2010
    australia
    Quote Originally Posted by w261w261 View Post
    the bulbs are : h4 12v 60/55w p43t , so what would i need to fix it ?
    Vanilla Sky's Avatar
    1999 Penalty Box
    You'll need a new combination switch. I have a couple sitting that I don't need, as long as you have a sedan or coupe.
    check the fuses inside the car...i think its a 15 amp fuse for the low beams
    Jan 2010
    australia
    its 10amp for the low beams. anyway bought a circuit tester (never use one before) but the guy at the shop said should be able to pinpoint out where the problem is.
    Jan 2009
    89 Accord LX-i coupe
    Illinois
    Last time this happened to me, it turned out to be one of the connectors at the top of the fuse block (under the dash). I can't remember which it was, it was the top row, either left or center. Pins of the connector (fuse block side) were corroded/burnt. Cleaned and tightened the connection and it was fine.
    Jan 2010
    australia
    Quote Originally Posted by -DWM- View Post
    fuse block side the side the fuses go on ?
    Jan 2010
    australia
    yep turns out it was the combination switch, the low beams still work sometimes wriggling the switch around so does this mean its repairable? do i have to remove the steering wheel to fix it? if someone has one willing to send to aus let me know thanks
    Jan 2010
    australia
    anyway took it apart sanded some of the copper part things on the switch now both highs and lows dont work ? i think i sanded the surface to much so now you can see the metal surface!
    Uploaded with ImageShack.us
    Jan 2010
    australia
    copper tape?
    Jan 2010
    australia
    ok went and got a new combination switch and still lowbeams are not working? lol...
  1. low beam out 88 accord, stumped
    By ping in forum 3geez Accords
    Last Post: 10-23-2012, 08:03 PM
  2. One low beam headlight not working.
    By Legend_master in forum 3geez Accords
    Last Post: 04-09-2012, 08:16 AM
  3. Headlights not working on low beam
    By Luis 89LXi in forum 3geez Accords
    Last Post: 10-26-2004, 03:59 PM
  4. Headlights stopped working and they both have new bulbs
    By Badboy2005 in forum 3geez Accords
    Last Post: 10-03-2003, 08:37 PM
  5. headlights only work on high-beam
    By Greg in forum 3geez Accords
    Last Post: 03-18-2003, 08:00 AM
