I just picked up a stock Honda stereo from the junkyard, and only the tape deck seems to work. It is the base model one with the manual tuner. The AM/FM lights do not come on. There is no static or anything, it is completely dead other than a slight click from the speakers when the power is turned on. When a tape is inserted, then it plays and can be heard fine. My wiring harness was cut off, but I cut off the plug from the junkyard one and wired it back into the hacked off one in the car. The antenna jack is plugged in and everything seems in order. Any idea if this is something repairable or should I just return this one?
