Results 1 to 8 of 8
Thread: USING A MAZDA MPV COMPRESSOR MANIFOLD ON ACCORD 10pa15e
    LOOK: MAZDA MPV COMPRESSOR MANIFOLD ON ACCORD 10pa15e
    Mounted up the 10pa15e to the 3G, couldn't find any in the junkyard, but walking around I found a Civic manifold and a MPV manifold, the Civic one would have the inlet/outlet facing the block. The MPV points straight up. I had to get creative with the hoses, and eventually I'd like to put the correct one or get a custom discharge hose, but here's how she looks!
    oops, part is 180 degrees off
    oops, interior is 60 degrees colder than outside
    Ugly, but functional
    Oh, and yes, the 10p15e and 10pa15e use the same mounting bracket
    Eric
    Re: USING A MAZDA MPV COMPRESSOR MANIFOLD ON ACCORD 10pa15e
    Good to know. Thanks!
    Nov 2000
    That's a really low temp reading at the vent. Mine NEVER did that well from the day it was new.
    LXi User CzEcHy's Avatar
    Jul 2008
    89 Accord LXI
    Gulf Breeze, Florida
    So was any fabrication needed to make it fit?
    Also, what vehicle was the compressor from - year, etc.
    I'd like to get my a/c colder since floridas heat and humidity are outrageous. And my "new" compressor isn't doing great at it.
    it's a reman accord compressor (10pa15e) it only came on 86-89 accords, it's not a custom adaptation. The problem was the reman didn't come with the manifold (the "adapter" that screws to the top that you hook up the hoses) and I couldn't find the accord manifold. A lot of other Nippondenso compressors have the same style bore for the manifold, I found a few different ones with similar manifolds. This particular manifold was from a Mazda MPV. The Civic manifold bolts up as well, but the hoses would have to plug in from the back (I didn't think it would work)
    The reason it's cold is because I did it right this time. I put a new condenser, expansion valve, drier, flushed all the lines, refilled with correct level of oil and r134, vacuumed (with the engine ), and wired both fans together. When the a/c is turned on both fans activate. When the car gets hot they both run at the same time.
    fyi the manifold came off a 1996-1998 Mazda MPV 10PA17C compressor.
    A lot of import cars use this compressor, just different manifolds
    Eric
    LXi User Buzo's Avatar
    Dec 2010
    North of Mexico
    Good job! Its hard to tell by the picture, so could you please tell me what compressor type your car originally had? Nippon-denso or keihin?
    I've had all 3 now. Originally a Keihin. Swapped it for a Nipondenso 10p15e a few years ago, it always had a very slow leak at the manifold that I couldn't fix. Now its the Nippondenso 10pa15e, which is basically the same thing but with a different manifold, which I could not find, so I kludged it with a Mazda 10pa17c manifold. It is a 3gee compressor with a Mazda manifold
    Eric
    Well that was pretty creative, nice find. It took me a couple visits to the junkyard to find the right manifold myself.
  1. ordered a new compressor, can't find manifold seal!
    By POS carb in forum 3geez Accords
    Last Post: 07-19-2012, 07:29 PM
  2. 10pa15e manifold
    By POS carb in forum Wanted
    Last Post: 07-11-2012, 06:46 AM
  3. WTB Denso 10PA15E
    By Xaisk in forum Wanted
    Last Post: 06-07-2010, 11:11 AM
  4. compressor manifold
    By night in forum Wanted
    Last Post: 03-12-2010, 11:13 AM
  5. FS: Mazda
    By kicker1_solo in forum Trading Post
    Last Post: 09-28-2003, 11:32 AM
