Results 1 to 8 of 8
Thread: whats a normal idle on start up?
    Oct 2002
    1986 Accord Dx/carb 213k
    When I start this car up in revs around 2000 for a good five mintues before it drops down to 1k. That's only after I tap the gas pedal a few times. Is this normal for a car this age? Or is it something I can adjust to make it go down? Will new spark plug wires help maybe? They look kind of shot. Idle speed screw? (I might note that I have gone through all vacum lines and replaced damaged lines/hissing noises are gone.)
    Also, I see where the PCV tube leads from the air filter housing to the cam shaft cover (that's it right?) but I don't see any pcv valve. There is what appears to be a pre-filter on the side of the housing where the tube mates up. I had bought a replacement valve. Does that go on the camshaft cover end? Or more towards the cleaner housing?
    Thanks all for the help. I almost have this thing running well.
    Jun 2002
    87 Accord DX Hatchback 5 Speed
    Cocoa Beach, Fl.
    yeah, that is normal for the fast idle, depending on the outside temps it runs at 2000 or so for several minutes. Your operating temp idle may be slightly high at 1 grand though, no biggie.
    Oct 2002
    Thanks, I'l leave well enough alone on that.
    Anyone on the PCV valve? Thanks.
    Jun 2002
    Cocoa Beach, Fl.
    the pcv valve is on the intake manifold right in fron of the carb and you can see a small hose bent in a loop, the valve is on the left side of the loop hose stuck into a grommet that is in the manifold
    Oct 2002
    Found it. It was down in there a bit. Now if I could just find where I laid down the new pcv valve? :super:
    Oct 2001
    87 Accord EX , 5spd , Manual
    als o check the FAQ's for everything about PCV valve !
    MIKE
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    How can you tell if your pcv valve needs changing?
    Oct 2002
    I was going to replace it because I didn't see anything in the records that indicated it had been. By the way the previous owner took care of the car, I doubt it had been done.
    Generally with a PCV valve, if you shake it and it doesn't rattle it's bad. If it does rattle is ok and doesn't need to be replaced. I replace mine at certain mileage intervals, whatever the spec is.
  1. Car feels like sh#$t on normal idle
    By pablo3264 in forum 3geez Accords
    Last Post: 06-02-2012, 01:46 PM
  2. Normal Idle?
    By DEEGO in forum 3geez Accords
    Last Post: 04-23-2009, 11:30 AM
  3. do not have normal fast idle speed
    By vasile in forum Carburetor Tech
    Last Post: 06-19-2004, 06:22 PM
  4. higher than normal idle and rpm differences
    By mgirl69 in forum 3geez Accords
    Last Post: 11-20-2002, 10:30 PM
  5. Normal Idle???
    By socal3rdgen in forum 3geez Accords
    Last Post: 10-31-2002, 01:31 PM
