Congratulations to thegreatdane for winning out September AOM award with his highly customized '87 2.0i sedan!
thegreatdane
Engine:168.3hp and 184.6Nm (136lbs/ft) torque
H22A DC Sports header, modified to fit and ported to match B20A ports. Collector replaced with a 2.5" collector instead of that pos 2" they are made with
2.5" custom stainless exhaust straight through with a Simons silencer and a Magnaflow muffler
B16A2 intake manifold
B18B distributor and custom block-off plate at exhaust cam
B&M fuel pressure regulator
Crower stage 2 B18B cams
Valve cover painted white
Black box removed
Fuel & Tuning:Converted to OBD1
P06 ecu converted to P28 and chipped
Boomslang 3rd gen Accord OBD0->OBD1 conversion harness
VSS sensor 6k resistor mod
Ostrich rom emulator
USB datalogging
Innovate LM1 wideband
Crome Pro tuning
Suspension, wheels & tires:Koni red struts front and rear
Ground Control coilovers
DC sports front strut bar painted white (not installed currently, there's no room for it with the B16A2 manifold)
17x7" Kosei Sniper rims w. Falken tires.
Interiorigital gauge cluster from RHD CA3 Accord
Auto-Up drivers side window switch mod
Exterior:New paint job in summer 2005
JDM power folding mirrors painted silver like the car
JDM CA headlight turnsignals - replaced the ugly dummy lense reflector
Removed small round front fender turnsignals
Door handles painted silver like the car
Badboy look welded to the bonnet
