Getting Harder & Harder To Start
Hey,
Here's the situation:
219,000 miles
Head reworked
New carb
Okay - when I first got everything back together, it ran great & it still runs pretty good. It used to start "super quick" but now, it takes longer & longer to start.
First theory:
I think oil is getting by the rings and clogging the spark plugs, making it harder to start.
A typical drive:
When I'm going down the highway, the engine often "rattles" . . . when I give it gas it quiets down - my guess is this "rattling" noise is due to either predetonation or could it possibly be just a worn engine or both or something else? The car is "noticeably underpowered" and I think this is just the result of worn rings (poor compression). If I can just remove the plugs and clean them every 2000 miles or so, that's no big deal - if it'll help keep the car going & make it easier to start.
I was planning on doing the rings this summer - to "tighten up" the bottom end to sort of match the refurbished head work. Of course, this time, I WILL take the engine out to do the bottom & have the block bored & cleaned & blah, blah, blah.
So . . . I'm going to remove the plugs today & check their status and then go from there. I am also going to get a compression tester . . . I can use it on other cars . . . I'll get the "screw in" type . . .
Another theory:The tube coming from the valve cover goes directly into my air cleaner - is the "oil spray" coming out of this tube & going into my intake manifold causing oil fouled plugs? I remember one time when this tube from the valve cover was unplugged & pointing straight up . . . you could see a "mist" of oil coming out of it. Am I supposed to have some sort of filter between the valve cover outlet & the air filter to trap or remove the "oil mist"? Should I just cap off the vent at the top of the valve cover & then also at my air filter where it connects now?
Comments, suggestions & recommendations are always welcome.
Thanks,
IPF
