problem after 5speed swap!
I went ahead and swapped out the auto for a 5 speed, Everything went well no problems....
started the car and she did the normal high idle thing for warm up..
After ideling for a few it kicked down the rpms to like 1300.. still alittle high, so i turned down the idle on the throttle body and only got it to go down like 300 rpms-then it happend!
it started pulsating from 900-1300 rpms..
do i need to adjust the TPS?
I also used the automatic ecu.
I then switched over to the manuel ecu and still the same problem..
Any idea's?
a couple hundred rpms isn't that bad but i have a full 3" exhaust and it is pretty loud.
