can i get a list of everything i need to do this:naughty:
Yes..--> here it is <--
The complete rear knuckle assembly off a SEi and E-brake cable also the proportioning valve
brake, dude... BRAKES..
You don't HAVE to have the proportioning valve, but its recommended.
^ yeah im not rocking one at the moment.
i appericiate all this information. does any one have pics of the parts and could i get all the parts from a parts store or do i need to goto a salvage yard
Junkyard is your best bet here is a link:
http://www.hondapartsdeals.com/hpa_p...onGroupID=5485
^ what?
Lxi prop valve here too no problems.
he should probably invest in the prop. valve since he's not rocking an lx-i, he's rolling a dx.
^ Lol
If you don't get the SE-i propo valve, there won't be any problem. It's just that the brake balance might be off a bit.
x2 on the prop valve
Everyone that I've talked to says it doesn't really affect it much.
Running a non SE-i valve won't harm anything. However, if you do not upgrade your front brakes you will need to learn how to control the car under hard braking. This is especially when it rains. The rear end will lock up and you will go into a slide, if you brake hard that is.
