How do I take out the back seat?? I want to take out the back seat and extend my boot space kuz I hate back seat drivers. Has anyone done this?? how would I go about it??
Its easier then hell dude. Driver side deap within the seat is a lil pin on the joint, pull that off, slide the seat towards the left side of the car from the right side and lift up, then pull the seat off of the other joint and your done. I'm sure once you see that red pin you'll know what to do.
I want to remove the back of the seat kuz the bottom of the seat will act as a suport for the wood I am going to but in there. The wood will go from the boot to the back of the front seats. I cant find a red pin.
hey you guys got the same avitar
just thought i would point out the obvious
to remove the back seat (assuming it's not a fold down) there are 1 or 2, 10mm bolts holding the backrest at the base. You have to push down on the seat where the backrest meets to find them. After you remove them the top is held on by hooks at the top. You have to push up on the seat to release them, you might have to struggle a bit but they will come out fairly easy. Good luck!
well fold down the back seat, and like he said the black stopper is whta holds it down. pop it out, take out the back seat and the bottom of the back seat is held by one 10mm bolt. lift the seat and slide it out of the U clips on the bottom (towards the front).
My seat is a fold down. I must be blind or something but I can not see a black stopper please explain in more detail.
Don't worry I found the black clip and by back seat is now out. I have now got a 2 seater Accord :)
I know man, I told KAOS how to put my Avator on his name.
