Performance parts list . 86-89 accord
I feel the need to make this thread for all the new members out there. I will TRY to list all of the performance part available for the 86-89 accord with the A-series motor, unless specified . I will not list the pros. or cons. of each item or power gain, just companies/members and products, and will be your responsibility to SEARCH!!!. "Other" section will be for parts that will fit with some modifications but again it will be your responsibility to SEARCH!!!. If you do not see the parts that you are looking for, it means that they will have to be custom made.
IMPORTANT KEY: (*) For FI models, (**) For carb. models, (+) Both models
Air Induction
-Short ram intake: Weapon R. * NOTE: I would recommend the DIY in the wiki over the Weapon R.
-Air Filters: K&N filters. + AEM, Injen, HKS, ect... have universal type filters that fit short ram intakes or CAI.
-Throttle body: Discontinued: Gude Performance.* NOTE: I would recommend a B series manifold first. see "other" section below.
-Intake flange: Discontinued: Weir Tech. +
-Intake manifold: Discontinued: Gude Performance. + NOTE: I would recommend an aftermarket B series manifold. See "other" section below.
-Individual throttle bodies (ITB's) kit: Discontinued: Extrudabody.+ Note: See other section.
-ITB manifold (EFI and twin DCOE40's): Discontinued: Extrudabody for EFI and twin DCOE40's. +
-Heat shielding gasket: Bisimoto. +
Other
-Cold air intake (CAI): Modified from another car or custom made. Perfect "how to" in 3geez wiki. *
-Intake manifold: Another option would be to use a B16/B18 OEM or performance manifold, will fit with a bit of work.*
-Intake manifold for B20A: Same as the A20.*
-Throttle body: Many for B-series manifold. *
-ITB's: Same as the intake manifolds. *
EXHAUST
-Headers: OBX. Discontinued: Pacesetters, DC sports and S&S. +
-Exhaust flange: Smith Innovations Stainless steel and Mild steel Discontinued: Weir Tech, BMC. +
-Catalytic converter: Magnaflow 49 state and California, Random Technology. +
-Cat back exhaust: Discontinued: Monza. + NOTE:An alternative would be going to a muffler shop with your own muffler and resonator.
Other
-Headers for JDM B20A: H22 headers and supposedly 90-94 eclipse DOHC non-turbo fit with a couple of mods. +
ENGINE
-Camshaft regrind: Delta, Colt cams, Crower, Bisimoto, Crane Cams. +
-Valve springs: Bisimoto. +
-Adjustable cam gear: Evolution Industries, Bisimoto. Discontinued: Golden Eagle. +
-Head studs: ARP from 98-00 Mazda Miata (Part# 218-4703)
-Main bearings: King engine bearings. Discontinued: Toga
-Con. rod bearings: ACL Race Series. +
-Weber kit: Redline (Weber 32/36, 38/38, or twin DCOE40's). ** Note: ebay is your best bet to find these.
-Adjustable fuel pressure regulator (AFPR): AEM, Aeromotive, Blox. *
-Fuel pump: Walbro, Venom. *
-Poly mount brackets: Cygnus X-1 (3geez member). +
-Copper Headgasket: Cometic gaskets. + Note: Will need to contact them.
Other
-Fuel rail: None for stock manifold but plenty for B series manifold. *
-Connecting rods: Aftermarket LS rods fit with some mods. +
-Pistons: I believe 83mm B series pistons work but check first.+
-Pistons for JDM B20A: B16 pistons fit with mods. *
ELECTRICAL
-OBD1 Harness: Might be discontinued CJS Wiring. *
-OBD1 dist. adapt. plate: Cygnus X-1 (3geez member). *
-OBD1 Jumper harness: Boomslang Fabrications. Discontinued: lx-incredible's jumper harness (3geez member). *
-Spark plug wires: NGK, Discontinued: Magnecor, Nology. +
-Other
-OBD1 Jumper harness: Any OBD0-OBD1 jumper harness will work with mods. *
DRIVETRAIN
-Aluminum flywheel: Action Clutch, Aasco. Discontinued: Clutch net +
-Clutch kit: Spec, Clutch Masters, Action Clutch, ACT (Disc only). Discontinued: Clutch net, Centerforce, Unorthodox Racing +
-Short throw shifter: Chedda_Jsauto's Adjustable short shifter and other cool stuff (3geez member). Discontinued: Pacesetters. +
-Shifter stabilizer bushing kit: Energy suspensions (16.1101R). +
-Other
-Limited slip differential (LSD): Wavetrac or any other B16 LSD with some mods. 5-speed only. +
TURBO
-Turbo manifold: Discontinued: Mosselman. *
-Other
-Turbo kit: Build your own from scratch.
ENGINE SWAP
-Motor mounts for B-swap: Innovative Mounts. Discontinued: PlaceRacing Inc. +
NOTE ON BISIMOTO: Some of the parts listed above may not appear on their website but if you contact them, they might have it. Been many years since last seen.
If you see that I have made a mistake somewhere or that I'm completely off about a part, please PM so I can correct it. Also, if you know of more parts that are not listed, PM so I can add them to the list.
Update: 8/9/15
Update: 5/20/24 - Added new parts, removed broken links, fixed links to some parts. I might come back in 10 years to update again :tongue:
Re: POSSIBLY ALL THE PERFORMANCE PARTS FOR THE 86-89 ACCORD :o
maybe add links to parts websites
Nice add. let hope they use the the search for this lol
So has anyone verified the 90-94 eclipsed headers.
import racer
Those were on the B20A
Great write up. Should be a stickied.
Pm a mod after everything is done and edited.
Good info.
So how much work to make h22 ones fit a20.Or would the obx ones be better.
The Eclipse header won't fit an A series motor. The center exhaust ports are offest on the A series, and the Eclipse header and H22 headers have evenly spaced ports like the B20A.
I'm watching this thread. If you don't mind, I'd like to clean it up and post it in the FAQ once we have gone through and verified that everyone is covered.
What about headers from a 4th or 5th gen accord? I found a set of 4-2-1 Dc headers that the guy says will fit on a 1994-1997 accord. will they fit on my A20A1?
honda crew
Read what he listed, if it's not there then it will need modifying....
No. You're getting away from offset exhaust ports again.
If it isn't meant to fit on an BT, BS, or A series engine, it's not going to work without changing the flange and moving the tubing to match the exhaust port. By the time you've put that much work into a manifold, you're not far from having a ground-up custom manifold.
While it is just metal, you do have to be able to cut, fit, and weld any manifold modification.
4th gen accord test pipe fits. Don't know if that's been thrown in yet..
gfrg88
correction to that. to make a 4th gen test pipe fit you must cut the exhuat pipe behind the cat and reweld it. the flanges are the same but they are positioned different
You also missed out the best clutch manufacturer Clutch net they also do ally flywheels too.
I like this.
Btw as far as the obd1 jumper harness goes, any obd0 to obd1 mpfi harness will work.
Ill see if i have anything to add later.
ghettogeddy
I thought about that but it really isn't that hard for people to google most of this stuff.
import racer
H22 and eclipse headers are only for the JDM B20A.
88lxi-shortram
I'll look into that or can anyone else confirm that?
rjudgey
Thanks, I knew I forgot one!
Tdurr
I like this.
Yeah, I learned that after I made the list.
Thanks for all the positive replies and keep them coming, I'll try and see if I can find more part to add to the list!
ill post pics.... i think i had to rotate the rear flange about 3 inches to get it to line up
88lxi-shortram
I don't remember cutting anything, or welding anything. But it's also been almost 8 years since I did it...
^^ yeah, it looks like they are offset by about 90 degrees.
^^ shifter bushing kit?
EDIT: never mind I found it. Thanks
obdriver6
Well shit. Maybe it was a different car??? Can't remember.. BUT I do know for a fact that I used a cheap test pipe that bolted up with no problems :dunno:
^^ Maybe somebody made test pipe for our cars back then.
For the info, I went to magnaflow. You can see that the 1st flange looks the same but its off by 90 degrees.
86-89 accord
http://www.magnaflow.com/02catalytic...irectfit=22623
90-93 accord
http://www.magnaflow.com/02catalytic...irectfit=22624
