actually im thinking of a better way. just krimp extra wires to those existing wires so that the fans can cut on automatically when my car is off, and so that i can cut them on when im in the car.
disconnect the harness from the thermo switch on the radiator and Splice the two wires together on the harness, the fan will always run when the car is on... or you can run one wire on the harness to a swithch in the car and then back to the other wire on the harness.. but then if you forget to turn it on you'll overheat again...
I was just wondering if it was the fan or no... cause if it't the water pump dieing of the thermostat then you're fan's might not come on anyways.
hey my fans started working againthe other day YAY. thanks for your help. idunno if ill do the switch or not... maybe inthe future. thanks.
