ok guys, I'm sorry I'm almost a year late on the promise of this little diagram, but here you go:
http://i296.photobucket.com/albums/m...lt_color-1.jpg
Fig.1:
Stock setup, fully assembled
Fig.2:
Bolt head snapped off, nut removed, 3 washers added, nut replaced
Fig.3:
Nut has been tightened down and bolt is starting to pull through (do not tighten to the end of the threaded section of the bolt)
Fig.4:
Nut removed, lots more washers added, and nut tightened again. Bolt is continuing to pull through the assembly.
Not pictured:
Remove nut again, add more washers, and continue to tighten until the bolt pulls completely through. Then get a new bolt (nut should also be replaced) and slop the inside of the busing with never-seize. Also liberally coat new bolt with never-seize before re-assembling.
Any questions?
