Re: List your boom-boom/etc. setup...
Head Unit: Kenwood KDC-X789
Amplifiers: Rockford Fosgate P2002, P2502, coustic(200W), Lightning audio(200W)
Subwoofers: Rockford Fosgate P2 10" and 12"
Speakers: Rockford Fosgate 6x9's REAR(Fully Powered), Eclipse 5.25" speakers front(Unamplified), BMW component speakers from 99 4 door BMW customly installed in front door(Fully Amplified)
Just installed my screen and ps2 as well :)
Headunit=Alpine CDA-9847
Speakers Door=Dual 6.5 2-way Speakers XP65-I
Speakers Rear Deck=Kenwood KFC-6959ie 6"x9" 2-way Speakers
Subwoofer=Lightning Audio 10" 300-Watt Subwoofer, P3.10.4
Box=Q-Logic Single 10 QLH-.6510SS sealed box
Power=Profile AP1040 80W x 4 Car Amp running the sub.
Satellite=Delphi SKYFi2 XM Radio
I-Pod=DLO TransPodFM Adapter
For right now I'm running the front and back speakers off the deck, I'll hook up a amp to them when and if I upgrade the speakers.
Simple setup but it hits hard.:D
Head Unit: Pioneer mp3 player.
Door Speaks: Pioneer 2-ways
Rear Deck Speaks: horribly blown Jensen 1-ways.
Amplifier: Rockford Fosgate 450S 450Watts RMS
Subwoofer: Infinity 1030W 250Watts RMS
Sub Box: Custom-built slot-ported tuned to 35Hz (built myself)
Ok, story about the bottom end (the sub and amp for you lay men and women). Bought the amp along with 2 memphis 12's in a box. the guy said the speakers are good, but the amp overheats. $100 for the setup. Not a bad deal eh? So, I hook it all up, and what do ya know, the amplifier works just dandy. No problems except I had to buy a bass boost knob from Rockford. Decided I didn't need 2 12's worth of boom, so I sold the 12's in the box for $150. I now have $50 and a free amplifier. I buy the Infinity sub off ebay for $25 (still $25 in the good), hook it up in my custom box, and 1 day later it's pushin' no sound at all. Fried it! Well, I got a deal on the Sub, so no big deal, might as well see if I can fix it. Took the Sub all the way apart, and I mean all the way. Found out after looking at it a little the problem was a simple wire going from the terminal on the sub to the coil. Didn't need to take the sub all the way apart. Oh well, I got a deal on the sub, wouldn't hurt to see if I can put it back together. I get the sub back together after quite a hassle of getting it lined up....there is very little room for error when lining up the coil with the magnet. Anyway. Subs working again, pounding hard as ever, and I have spent a total of -$25. I'm a happy Camper. Thanks for reading my novel.
4 2 way kenwood 160 watt 6 1/2
sony mp3 deck
12OO WATT kenwood 5/4/3 channel amp
1 Farad cap
2 12 inch Infinity 1400 watt subs
sony head unit
front: infinity kappa perfect 2 ways
front dash: two infinity kappa perfect titanium tweeters hidden in air vents
middle: factory acura legend map/dome light with twin tweeters, infinity kappa perfect tweeters
rear door: custom mounted infinity kappa perfect 2 ways
rear: infinity kappa prefect 3 ways
rear seat: 92 prelude rear seat conversion with optional factory center speaker, infinity kappa perfect 4 way 6x9
sub: two infinity kappa perfect 12's 2000w dvc
amplifier: the biggest infinity makes, reference series 1210 mono, pushes 1350watts.
amplifier:infinty reference 7641 4 channel sterio amp
enclosure: custom flush mount sealed box built my self
alpine HU
Infinity Reference series components (front)
Infinity Reference 6x9's (back)
Alpine Mono Block Amp
Alpine 4ch amp
Infinity Reference series sub.
Lightning audio wires...all around
Alpine 9853 HU
Pioneer 4x6 (front)
Alpine 6.5 2 (back)
Kicker 1250xi Amp
Two generic 100 watt peak 10" subs
Stock Wiring
Setup to come:
Same HU
Alpine 6.5 components (front)
Alpine 2 channel amp
Pioneer 4x6 (front-moved to custom fiberglass enclosure)
Alpine 6.5 (back)
Same sub amp bridged
Two 10" Alpine Type R subs (in custom fiberglass enclosure to save trunk space)
16g wiring to all speakers
Same wiring for subs (already overdone)
Sound deadening in trunk, doors, and rear panels
i get my bump from
1000 watt- max amp
jl sub 300watts 12w
100 watt jensen
2 speakers in the back 180 watts each
panasonic deck
4 tweeters
headunit:Pioneer 7600 mp3 player
amp:bazooka 600 watt mono sub amp
highs /front:memphis 5 1/2 with crossovers
highs/ rear:memphis 6 1/2 with crossovers
subs:planet audio 12's with q logic box
I probably have the crappiest sounds here but oh well...
Sony Xplode Head unit
Sony Xplode 16cm Speakers x4 (in the factory holes)
2 x 12" Sony Xplode Subs
Custom Made Sub box
600 watts Sony Xplode Amplifier
I know it’s not much but my mate works at super cheap auto & he could get me major discounts on all of it so I couldnt pass up.
Old setup:
HU: kenwood kdcx-817
Front speakers: Jbl 3-way gt series 6.5 inch
Tweeters: Kicker impulse with crossover
Rear speakers: jbl paper cone 6x9 (suprisenly it sounded good.)
Subwoofers: 2 12inch soundstream slp mules
Enclosure: custom made sealed box
Amp: rockford fosgate 500a2
Updated system:
Pioneer DEH-P6700mp HU
American Pro "Bass Machine" 9 band equalizer (not in yet)
Infinity Reference 6012i 6.5" (180w max) in front
Pioneer 6.5" (140w max) in back
Tsunami 4 channel 560 watt amp (not hooked up, need multi-amp kit)
Power Acoustik LT980/2 980watt (280rms per channel) amp
2 MTX 10" Thunder 4500's @ 225rms
Yeah...
Originally Posted by mykwikcoupe
oh and everything ahs a two stage alarm. the first stage is the alarm going off. The second stage is the shotgun out the window. I sleep light and I park under my window in a well lit area but het its worth a challenge is your up to it and yes Ill shoot you and ask later.
:gun: ^^ haha right on
front - 6 1/2 shitty ass walmart speakers tht i got for 30 bux
back - 6x9 3 way panosonic speakers
woofer - 2 12 inch sony Xplods 1200watt
Pyramid 1000 watt amp to run the speakers
sony xplod 1200watt amp to run the woofer
.... its all mixxed up but it sounds amazing
Sony MDX 9900 HEAD UNIT
ALPINE TYPE-R 6.5 COMPONENTS IN FRONT DOOR
KICKER 3-WAY 6x9 IN REAR DECK
ALMANI PA 800.4 , 100X4 rms PUSHING MIDS AND HIGHS
ALPINE MRV1005 850 WATT rms PUSHING ONE SUB
ONE 12 INCH ALPINE R-TYPE SUB IN ALPINE ENCLOSURE
THIS CAR HITS REALLY HARD FOR ONLY ONE SUB
DAM this rob me list is still going.
