This topic has been covered before. I searched. There were several recommendations NOT to use the new tubes and bolts that come with cheap aftermarket front UCA's along with the advice to reuse the originals. The new parts seemed quite solid and were a good fit so I used them. It may have been a mistake.
It's is so weird. My highway ride is quieter and the vibration from in the steering wheel is pretty much gone. My upper ball joints in the old UCA's were shot. What is weird is that intermittently I get noises from the front end when going over bumps and when taking turns at low speed. If I bounce the car when parked the UCA's are quiet. I used plenty of lithium grease when assembling and the bushings didn't take too much effort to install. I greased them and used my bench vise to press them in.
I don't understand why properly fitting parts would cause this and I am not eliminating the possibility that the noises have another source besides the UCA's since we all know that improving rigidity in one area can aggravate issues in other areas. If I have to toss the UCA's I just installed and get better ones I will do that in the near future, but I was wondering if anyone had any ideas. I am so sick of sounds from the front end like the car is falling apart. It's embarrassing in an otherwise pristine vehicle.
