Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 131
Thread: Megajolt conversion
  1. #101
    Jun 2010
    Re: Megajolt conversion
    It did great, I was a little hard of hearing for a few hours after running this loud ass thing for 15 hours straight lmao.
    I nailed a dip in the road in Knoxville that may have fucked a tie rod. You probably know it, was around exit 380 something. Bottomed the car out. Been tracking to the right ever since.
    Originally posted by ShiRen:
  2. #102
    The double bump right in the downtown area...I smash my Camaro off them everyday on the way home
  3. #103
    Jun 2010
    It's on i40, probably the one though. Those hurt.
  4. #104
    Woohoo! Go go go!
  5. #105
    Jun 2010
    So i realized something and I come to the conclusion that I am quite daft sometimes.
    The reason it wouldn't run right is because I have the trigger wheel 180 degrees off. I put my sensor in the front of the engine, the build I was using as a reference has his sensor on the back of the engine. In his case, the missing tooth will point down. Mine should point up (90 degrees relevant). woops...
    Going to take the pulley off again and have a machine shop cut a keyway into it so all I need to do is spin it 180 degrees and presto magico.
    Did have to order a new sensor cause mine kind of got ran over....
    I may have forgot I had to unbolt it to get the timing belt through and may have left my bracket laying on the lower crossmember. It may have fallen off down the road when test driving the car after putting the new belt on.... then got ran over by another car before I could fetch it from the middle of the road...
    but hey, bracket is perfectly fine, didn't break or get bent.
    Sometimes I can be pretty dumb... lmao.
  6. #106
    LX User Fixedit's Avatar
    Feb 2015
    Oregon
    N’awh dang, man! Well, at least you(‘ll) have your work cut out for you! lol can’t wait to see how it does put back together right
  7. #107
    Jun 2010
    So finally got the controller to interface with the laptop I have and have been fiddling around with the timing map the unit came with.
    Anyone have a good base map for this engine or at least numbers to roll with?
    Been looking around on google and autosports website which has files for a bunch of engines but not really anything for this one in particular. Doesn't seem to be a popular engine to convert lol
    This is the base map on the unit:
    rpm-->1k 2k 3k 4k 4.5 5k 5.5 6k 6.5 7k
    v-load
    20-----12 20 25 27 30 32 35 36 36 36
    50-----12 20 25 27 30 32 35 36 36 36
    60-----15 20 25 27 30 32 35 36 36 36
    70-----15 20 25 27 30 32 35 36 36 36
    100----15 20 25 27 28 29 30 33 34 34
    135----12 20 23 23 23 25 25 25 25 25
    160----12 18 20 22 22 23 23 23 24 24
    180----10 15 20 22 22 22 22 22 22 22
    200----10 15 20 22 22 22 22 22 22 22
    230----10 15 20 22 22 22 22 22 22 22
  8. #108
    Jun 2010
    hm.. I found a map for an ET2. That's the prelude twin carb engine isnt it?
    Guy says it has dual webbers and a header on it.
  9. #109
    v-load
    I always been curious what the time curve looks like too. Shane might have an idea. 36 degrees sounds like alot thats where old domestic V-8 usually run where as modern Hemi and Chevy run less than 20. I never see more than 21 on my LT4 at WOT.
  10. #110
    Jun 2010
    Looks like the ignition map I found is from this guy:
    https://www.3geez.com/forum/classic-...tor-build.html
    His map is even more radical than the base map the unit came with. Says it ran great. He is factoring in a cam and much higher compression ratio though so that may throw a wrench into the mix.
    This is his map:
    rpm---->5 8 1k 1.2 1.6 2k 3k 4k 5k 7.5k
    v-load
    20-----20 18 18 20 29 36 40 42 42 42
    55-----20 18 18 20 29 36 40 40 42 42
    60-----20 18 18 20 29 36 40 40 42 42
    65-----20 18 18 20 27 34 38 38 40 40
    70-----18 16 16 18 25 32 36 37 39 40
    75-----12 15 16 18 24 30 33 36 38 39
    80-----6....9..10 12 19 24 30 35 37 38
    84-----4....7...8..10 12 21 28 33 35 36
    87-----2....5...6..8..10 18 27 33 35 36
    90-----0....3...4...6...9 14 26 32 34 35
  11. #111
    Jun 2010
    From what I've been reading from old posts on here and some google stuff, these engine like a lot of timing in the higher rpms/heavy load range. I've found a map from cygnus that went as high as 44degrees at 5k. I went in a punched his numbers in to a map but did have to remove two lines since his was a 12x12 and MJ is 10x10. I took out 500 and 7.5k. Ran the map as 700, 1k, 1.5k, 2k, 2.5k, 3k, 3.5k, 4k, 5k, 6k. We'll see how it runs off the base map and then my map.
    Monday I'm pulling the pulley and reworking it. All I need to do is cut a keyway into it so I can set it the correct direction. Everything is still wired up so just a matter of getting the pulley right and realigning the new sensor.
    She might just run this week, so exciting!
  12. #112
    Jun 2010
    Wheel is reset to the correct position. Ran out of daylight so I'll try to fire it up tomorrow.
  13. #113
    Jun 2010
    Its alive!
  14. #114
    Jun 2010
    Definitely needs some work. Idles good and off throttle is good, has a stumble at 2k that persists throughout the rest of the range so got to figure that out.
    The crank advance was too high and it was spitting on startup but turned the crank adv down and is fine now.
  15. #115
    Get that baby ready for Cars and Coffee in the fall!
    Harper Auto Square
  16. #116
    Jun 2010
    8am?! Ewwww lol
  17. #117
    Jun 2010
    SO been tinkering around with it most of the day...
    The 2nd map I posted it was NOT happy with so I reloaded the base map the unit came with and she ran much better. Still some stumbles in certain places though.
    This shit is cool as all hell though. Was getting a stumble at 2k at 50-60kpa vacuum. Added 2 degrees to those two spots and stumble goes away. So cool. Looks like I'm going to have to go through the whole range finding the bad spots and adjust the map accordingly.
    Leaving the distributor hooked up for now since I still have to drive it to work and can just swap two wires around to run off it until I get a good working map figured out.
  18. #118
    Another idea is you get lost on timing pull a spark plug and look at the ground strap that will tell you where the timing is.
  19. #119
    Jun 2010
    You'll have to explain that a little better lol
  20. #120
    https://howto-kuidas.blogspot.com/20...g-reading.html
    I didnt read this all but ...the ground strap tells you where your timing is at. Kinda handy if your lost on your tune up.
  21. #121
    Jun 2010
    Ah, well that's neat. Thanks for the tip.
  22. #122
    Yeah you more or less want it on the "bend" of the ground strap.
    Some of the other readings usually you have to run a car WOT then shut it off and pull the plugs. If you idle around on them it will ruin the reading as far as rich/lean. So thats usually done at a drag track.
  23. #123
    Jun 2010
    Sorry for the lack of updates here but being it's winter and all, cant do much. I'm going to redesign my sensor bracket because I believe I narrowed my issues down to losing signal at the trigger wheel..
    Also going to build a new wheel/crank pulley.
  24. #124
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    I have been looking into megajolt recently... I just wanted to drop somewhere that you can use GM 2 post dis coils too, like from a 3800 v6. This will let you run 2 coils instead of 1, less work for them so you can run more aggressive timing settings. Going to a Ford dis coil pack was bothering me because I don't know how it would hold up to my msd box. Tech Wiki - EDIS : Datsun 1200 Club
  25. #125
    You can buy the Ford coil packs from MSD directly. I run one with my Megajolt... It's really just 2 coils in one package anyways. I prefer the package over seperate coils. You can run individual coil packs on this setup too, if you want one on each plug. But it will still be wasted spark.
    https://www.amazon.com/dp/B000630380/
    Though there's really nothing wrong with the Ford coil packs.
  1. 2ndGenGuy's '81 Hatchback MegaJolt Lite JR Conversion
    By 2ndGenGuy in forum Project Central
    Last Post: 02-25-2015, 04:32 PM
  2. ItzDave's Megajolt thread!
    By itzdave in forum Carburetor Tech
    Last Post: 10-13-2011, 08:22 PM
  3. OBD-I conversion
    By Nik247 in forum Performance
    Last Post: 07-26-2010, 12:49 AM
  4. E85 conversion kit
    By nswst8 in forum EFI Tech
    Last Post: 12-14-2009, 12:24 PM
  5. HID conversion
    By Blaaz in forum Classic Honda Community Chat
    Last Post: 07-06-2007, 09:31 AM
