Page 4 of 4 FirstFirst 1234
Results 76 to 100 of 100
Thread: PROJECT, 4G MAP SENSOR
  1. #76
    Re: PROJECT, 4G MAP SENSOR
    i lost lots of mpg when i did this...when i removed it...it all came back up..but then my o2 sensors went so...
  2. #77
    LX User 895spdforfree's Avatar
    Aug 2004
    i did it and i noticed the engine idled/ran smoother, and just gave an overall smoothness to the powerband, maybe 1 hp increace haha, well i only got a short ram so yeah..
    uhhhh
  3. #78
    LX User rustlude87's Avatar
    1987 Honda Prelude Si
    like our motors are 2.0 but you know the inetgras are 1.8, and the map sensor is from a 2.2 won't it just dump fuel in the integra? like a lot more than us
  4. #79
    thats what i would assume ^^^
  5. #80
    10/Honda/Ridgeline
    NJ
    Quote Originally Posted by rustlude87
    a Map sensor checks the vaccum in your manifold and thus adjusts your ignition, not the fuel delivery. The fuel delivery is taken care of by your fuel pressure regulator which increases or decreases your fuel pressure. IF the vaccum is high (closed throttle aka idling, or at high load) it increases the advance on ur ignition timing (also at high engine speed and WOT) and at normal mode, it retards the timing.
    so a map sensor does not add fuel as you know.
  6. #81
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    ehhh the map sensor is just a sensor. It doesnt do jack shit. And it certainly doesnt correct the ignition timing on a car with mechanical ignition correction.
    It reads the vacuum or pressure in the intake manifold so that the ecu knows where in the fuel table to look up how much fuel to inject. That's the simple side of the story..
    Link to my 3geez garage
  7. #82
    ok i did this mod like 2 weeks ago. it was very easy the wires almost had the same colors. so i crimped them on and went to plug it in....i did notice it has a lil extra pull all the way to redline. but i also notice that my MPG went down...im geting 25mpg and 80% of that is highway driving under 75mph. with my stock map senson i would get close to 32 mpg....so yeah it took a big dump on gas...anyways you cant beat a free mod...and dyno results would be cool.
    Apr 2007
    One Blue 1986 Accord Lx-i hatch back, One Gold 1986 accord Lv-i Hatchback
    NC
    dose it matter which one the b18 d16 b16?
  9. #84
    i forgot to post my findings......i finally got around to dyno it with a stock and an 4th gen sensor
    so i gained 2hp and 4 pounds of torque to the wheels...not bad for a thing you can swap in 30 secs
    yeah but is the 1-2hp gain worth the 10mpg loss in fuel efficiency? seems like the map sensor is more like something you want for track day than for daily driving
  11. #86
    well since they are easy to swap, you could just rig up a switch or something so you can just choose between which one you want with a flick of a switch
  12. #87
    Quote Originally Posted by A18A
    Good idea.
  13. #88
    how do you switch the vacuum hoses? or do you just split them? and i think thats a lil much for a 2hp boost.. i can put on a red H badge and get more hp
  14. #89
    ^thats what i thought of the whole map sensor idea from the start
  15. #90
    Messy whats your setup motor wise?
    Those are great numbers. I wish there was A/F ratio to show what was up. That would tell us if the Map sensor was richening the fuel or it was just a better sensor then your original.
    I was wondering too if the ECU needed to be reset to take advantage of the change.
  16. #91
    he's got an intake, exhaust and adjustable cam gear, plus the map sensor.. i think thats it
  17. #92
    LX User skycam_313's Avatar
    Dec 2006
    88 DX Coupe
    hayward, CA
    makes more sense...
    mods:
    stage 4 vacuum removal
  18. #93
    im running my stock one right now....i only put in the 4th gen one to see if there was any difference. now...i know there is one.
    yeah fitz is right...i only have teg Intake, full exhuast with high flow cat and muffler, adjustable cam gear...it has no markings so i tired to adjust it to OEM specs but i think its more like -1 retard, blaster coil. thats it for now....i already have plans to rebuild the upper half of the engine. i have most of the parts. i got a friend that can help me do an OBD1 swap...im looking for 130-140whp after im finished.
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    does anyone have any pictures of this please?
    does this mean i get to toss my stupid black box under the hood?
    -Harvey
  20. #95
    haha no the map sensor is just one small item inside the black box
    it's connectected to the wire with the 4 connections that goes into the black box on the front side to the left
  21. #96
    LXi User coope's Avatar
    Sep 2006
    89 accord lxi efi
    mississippi
    dame this thread is old but i did i it and got a lot more top end now i can hit 130 and it's easy only took 5mins
  22. #97
    Feb 2004
    89 accord lxi
    down by the bay
    i seem to remember seeing a graph somewhere in the shop manual of the voltage output of the map sensor corresponding to the amount vacuum. if i can find that, maybe the same thing is listed in the 4g manual and then we'd know if there is any difference.
  23. #98
    Ichiban's Avatar
    North of You.
    Quote Originally Posted by A20A3
    What else, other than the MAP sensor, is in the hellbox that is required for proper functioning of the ECU? I'm surprised that the MAP sensor is not mounted directly to the intake manifold.
    ICHIBAN!
    "Now, even more better!"
  24. #99
    Feb 2004
    89 accord lxi
    down by the bay
    umm, there's the variable solenoid for the egr lift control, solenoid for the vac advance, and the solenoid for the intake manifold secondary runner butterflies if the car is 88/89. there might be one more but i can't remember right now.
  25. #100
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Quote Originally Posted by Strugglebucket
    thanks for that advice man. i have no EGR anymore(i put aluminum plates on the IM where the valve is and where the pipe from the exhaust hooks up)so i guess i can get rid of that solenoid...and possible tuck and hide all the other necessary BS somwhere else...hmmmmm...
    i got my 4G MAP sensor yesterday, still gotta put that on too.
    -Harvey
  1. cylinder position sensor and TDC sensor
    By newaccorddriver in forum EFI Tech
    Last Post: 04-21-2011, 10:02 PM
  2. elijahs accord turned into my big, unexpected project AKA project springtime
    By newaccorddriver in forum Classic Honda Pics & Videos
    Last Post: 07-16-2010, 04:16 PM
  3. Coolant temp sensor tw sensor
    By Bluntman in forum 3geez Accords
    Last Post: 07-06-2009, 06:12 PM
  4. Project, 5th Gen Map Sensor
    By mushroom_toy in forum Restoration & Custom Fabrication
    Last Post: 08-21-2007, 01:42 PM
  5. Need help! Broke a sensor wire (green sensor)
    By SMaurer32 in forum EFI Tech
    Last Post: 10-31-2005, 08:06 AM
