Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Thread: need to know how to pull rear disks!!!
    Re: need to know how to pull rear disks!!!
    ok so i better start looking for some sei coupe ebrake cables huh...anyone know where to start lol
    Mar 2005
    1989 Accord LX 70K miles
    Nashville TN
    i'm not sure about the 4 dr vs. 2 dr cables being different...don't think there is one but I don't know the correct answer to that. But i priced out some at that website and they were like 60-75 bucks if i was looking at the right item.
    I'm doing this same coversion for my kids car...you might be prepared to rebuild the calipers if they are questionable. I'm having to upgrade the front discs too...the lx are smaller than the lx-i's/sei's. That brings me to a question...there's ton's of lx-i's in the jy...can i use the front hub assembly off one of those? They are same as the se-i's correct?
    I was getting the setup off a jy car and only got some of what i needed...when i went back to get the rest the car was gone...they sold it...arggghhh. But while i'm locating another sei i'm doing the calipers up right. Will have all 4 ready to go...new rubber...all polished parts...casing sandblasted and painted. I have exploded pics of the rear calipers if you need them for any reference
    Also...i'm considering redoing the bearings while I have everything apart...I hope this is all worth it. Estimate that running about $50 bucks to have them pressed in.
    Another tip...the online manual is very helpful. I'm not sure of the link but you can find it w/ a search.
    see this is how all newbies should be! he searched, found the right info and even knows a lot more than i do. then i again i know nothing lol
    you get my vote for newbie of the year powder!
    Quote Originally Posted by powderkey2
    Also...i'm considering redoing the bearings while I have everything apart...I hope this is all worth it. Estimate that running about $50 bucks to havethem pressed in.
    86-87 LX-I and 86-89 LX are the same size on the front disk. If you want bigger rotors you have to get front 88-89 LX-I hub assembly. If you do that you cannot use the 86-87 calipers with the 88-89 LXi hub assembly.
    Mar 2005
    Nashville TN
    check on the sizes...i was able to pull the front calipers from the se-i and have rebuilt them so i guess i can snag the hub assemble from an lx-i...that just leaves me the rear assembly,cables, proportioning valve...thanks.
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    You can get all the parts for the swap direct from honda, so ant bits, and peices you need, you can get from them.
    Make sure it is an 88-89 LX-i that you grab from. Good luck
  1. sei rear disks question
    By 88lxi-shortram in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-10-2012, 02:39 PM
  2. Sei rear disks are they worth it?
    By bullard123 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-06-2008, 10:17 PM
  3. Rear Disks, SE-i
    Last Post: 06-22-2007, 11:53 AM
  4. does anybody know if the prelude rear disks are the same?
    By lostforawhile in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-28-2006, 11:52 PM
  5. IF you cant fix'em...Pull'em
    Last Post: 01-10-2005, 11:57 AM
