Results 1 to 25 of 33
Thread: Well my custom hood is almost done but now car won't start.
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    Well my custom hood project will be done tomorrow. And I have been charging up the battery. It will crank and I had it going once but it died after I let off the gas. I noticed some smoke coming from the engine and I stopped trying. It looked like it was coming from the starter solenoid, but the starter and solenoid weren't hot at all just a little warm. I checked around that area for burnt wires but nothing. I'm not quite sure what to think right now. It has a half tank of fuel and the oil is good. I don't think it could be a coolant leak b/c nothing was hot enough to make it smoke and it didn't smell like smoking coolant. And the belts were sqweeling.
    I knew the car was going to be mad at me for not driving her for 2 months.
    What do you guys think I should try? I'm going to put my midtronics tester on the battery to see if it's got good health and charge. But, I'm kind of at a loss about the smoke from the starter area...
    And I will get some pics tomorrow if I can get the beast running.
    -Mike
    Mankato, Minnesota
    Re: Well my custom hood is almost done but now car won't start.
    Alright I got it going for about 2 minutes. Belts were sqweeling and smoking and yeah I smoked a belt. I run to the store and get some new belts. I broke the one that goes around the alternator, water pump, and crank. Since that one is closest to the motor I better replace all 3 belts so I don't have to do it again. I'm sure I glazed them pretty good looked like a burnout competiting in my backyard.
    But it runs so that's a plus.
    Didn't smoke from the starter area this last time either. The smoke could have been from the belts but drifted to that area I dunno.
    Alright off to the store.
    -Mike
    Mankato, Minnesota
    Well I decided to turn the pulleys while I was figuring out how to replace all the belt (except timing belt). And I found out that my alternator pulley wouldn't turn. Everything else was good but the alternator pulley. Do you guys think I should force it after spraying it down with some lubricant? Or do you think I need a new alternator? I should be able to get the alternator through the top since I don't have a lot of crap in my engine bay. But I don't really want to buy an alternator either...
    What do you guys think I should do?
    Mankato, Minnesota
    Well I bought a new alternator (lifetime warranty) and all new Gatorback belts. And got a bunch of other stuff from Autozone so I would get my $20 giftcard
    The alternator most like has a bad bearing so yeah I will have fun with that tomorrow.
    Nov 2002
    Ridin Dirty in New York
    yeah if it wont turn freely its a bad bearing, and the bad bearing makes soo much heat and noise it smokes the alternator
    2.0Si User 3G Jester's Avatar
    98 Av6 3oh
    Sacramento, CA
    thats exactly happened with my 3g when i tried to get her running again after like..10 months of sitting there.....then i left for the military so i didnt persue it farther then you. it was a rough start and i had to replace the belts..again....i started by getting all new belts but everything was seized.
    -Travis-
    89 accord LXi 2dr 5 speed Monster, yes it's factory
    LF,TX
    hey the smoking from the starter area is from the wire connections on the sylinoed. won't look dirty but probally is.
    Because god hates you and he isn't trying to hide it anymore
    Mankato, Minnesota
    Well I decided to not replace the A/C belt. Figure I should just cut it and not replace it since I never use it. Do you think I can get the alternator out from the top? I have a lot of stuff removed and I think I can get it out since I can clearly see it. Just might have some problems with the bolt underneath, but I will just have to see in the morning. And tips or advice is always welcome.
    -Mike
    Mar 2005
    1896 Accord DX
    Manteca Ca
    I had to replace the alternator on my carb. it wasnt so bad, it has to be done from the bottom if you have all of the vacuum and smog stuff hooked up.
    Nov 2002
    where are pics of this custom hood mike? is it a cowl induction?
    Mankato, Minnesota
    I don't have the hood on yet. And I have I think 100% of the smog crap out of my car So I guess I will get it from the top then.
    Mankato, Minnesota
    And yes I cut out a part of the hood right above my edlebrock air cleaner so I would get some nice air.
    Mankato, Minnesota
    Well I can see why my car didn't pull a lot of amps when running. There was no adjustment nut on the alternator to keep tension on the belt. I was like wtf somethings missing. 1 bolt/nut left to get off the alternator. (the tough one )
    Mankato, Minnesota
    Alright I got it all back together and the car runs good. I put the hood on and it looks mean! I like it and I still can use my windsheild washers but you can't see them. I'm going out now to get some paint and I will attempt to paint it tonight.
    -Mike
    Mankato, Minnesota
    Alright I just finished priming, painting, and clearing the hood. I went with gloss black Man do I want an all black accord now. It looks hot. Or I could still be high from the paint fumes. Or alcohol, I dunno I will have finished pics tomorrow.
    -Mike
    cool, must be nice to have time lol
    Mankato, Minnesota
    I don't exactly have a lot of it, if you implying I do.
    oh no im not saying that you have no life just that it must be nice to find the time. cuz i sure cant....school/work/girlfriend/child/ and all i get is 4 hrs of sleep. oh and im not being sarcastic
    Jan 2004
    Bucket
    Bay Area, CA
    damn a child at age 20? owned greatly
    any pics on the hood mike???
    3geez for life.
    damn ct.....totaly flaming on me these past days
    Mankato, Minnesota
    Here's one pic I couldn't get more than this one to load on my cardomain so I will have to keep trying.
    Mankato, Minnesota
    I don't know what the heck is up with my cardomain, but it won't let me upload anymore images. So you guys will have to live with the one pic for now at least. Sorry.
    -Mike
    why dont you use imageshack or photobucket?????
    sounddomain is being stupid....you cant even browse through pages of the members because their damn server is probably overloaded and cant take the heat. anyway just use imageshack it will save lots of trouble
    plus i want to see more pics. lol
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Nice, but why are the light covers on there?
    LX User Soundy's Avatar
    A20A2 2bbl 5spd 1987 Accord LX hatchback
    Pitt Meadows, BC
    Quote Originally Posted by Mike's89AccordLX
    Maybe the car doesn't like its new hood? Maybe you should put the original one back and keep your car happy
  1. Project Custom Hood Cowl :)
    By Mike's89AccordLX in forum Interior & Exterior Care
    Last Post: 09-18-2005, 08:56 PM
  2. Custom Z3 Vented Hood Project
    By Project-LXi in forum Interior & Exterior Care
    Last Post: 06-04-2003, 06:31 AM
  3. Replies: 11
    Last Post: 02-11-2003, 07:38 PM
  4. Custom hood
    By 89AccordGSR in forum Classic Honda Pics & Videos
    Last Post: 12-01-2002, 11:51 AM
  5. OEM or CUSTOM HOOD PLEASE LOOK
    By custom86Lxi in forum Interior & Exterior Care
    Last Post: 08-10-2002, 06:57 PM
