Results 1 to 7 of 7
Thread: Can I replace front stuts on my own?
    1988 Honda Accord DX
    Chicago
    Thumbs down Can I replace front stuts on my own?
    Is it pretty easy to do (I have access to a good shop)? I don't want to waste a few hundred bucks getting them professionally replaced.
    Feb 2004
    Panama City, FL
    Re: Can I replace front stuts on my own?
    Yes, its pretty easy to do assuming that no bolts are frozen in place and you have a spring compressor.
    Pgm-fi conversion 4-16-05
    OBD1 11-25-06
    Turbo 2-26-07
    i think there is a how to somewhere in this site....ill look for ya...
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    you just need a spring compressor. can rent one from your local auto parts store.
    Unbolt the top 3 bolts (14mm) and lower control arm bolt (17mm) (end of the pinchfork) and loosen the pinchfork bolt (14mm) and undo the brake lines ( 12mm) and you can take out the strut spring assembly and use the spring compressor and then get a pair of pliers to hold it while you get a 10mm (i think) and loosing the top hats. Then remove it all and take out the strut and reverse order!
    I'd like to do this job, but the last time I tried, I couldn't find a spring compressor that would fit the front struts. Does anyone have a brand & model that works? I've used search, and whenever people ask, the answer is something like: well, I got one at a local auto parts place a few years back that worked ... which doesn't really help if you need to find one yourself.
    TIA.
    Hyong
    LX User T-Funk's Avatar
    89 Accord LX
    Edmonton AB
    powerbilt makes one that barely fits with a little wiggling and patience
    unfortunately every auto parts store around here has replaced the good kind with those
    i liked the kind that had c-shaped pieces that you fit around the coil and then connected with nuts through the bracket
    SEi User halxi's Avatar
    88 LX-i Coupe
    Brighton, Colorado
    ghetto spring compressor
    i stood on mine while i held the piston of the strut with pliers and losend the bolt with a 10mm open end wrench, worked fine. Then i used the weight of the car to compress the spring and tighten the cylinder/piston.
    No performance loss from what ive noticed, and everything rides fine.
  1. Anyone here ever replace front bearings like this?
    By nfs480 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-14-2010, 04:52 AM
  2. replace front struts, but what else?
    By timber_cruiser in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-30-2006, 04:44 PM
  3. Front end clunky. What to check, what to replace?
    By maxsideburn in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-11-2006, 12:45 PM
  4. How to replace front strut/springs without compressor......
    By miss_accord in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-10-2005, 12:39 AM
  5. Looking to replace front speakers, again.
    By danronian in forum Interior & Exterior Care
    Last Post: 11-03-2003, 09:46 AM
