Just finished putting in Justin's rear upper strut bar, had the lower one on already. I'm doing one at a time to see/feel the difference. Big difference. I noticed after I put in the lower rear bar tracking was much more communicative, less slop, tighter feel. I didn't feel as much of a difference after putting in the upper rear until taking higher-speed turns. At higher speeds, I felt the upper provided more stability and feedback without slop. Once again, the car just felt tighter so I had much more confidence going into a turn faster because I wasn't afraid of losing my line. Turn-in tightness isn't as noticeable as the stability midturn, which is much better than w/out the bars. Trailbraking is much easier because the backend isn't bouncing all over the place and it feels like movement is isolated in one plane a lot more. Overall I'm very happy with how they feel and can't wait to feel what the front bars will do ...... BTW, I had these powdercoated myself.
(pic 1) view of the right mount
from the back seat........ (pic 2) I even managed to save the top shock cover by trimming off a bit ..... (pic 3) view from the trunk
lower tie bar. It was a bitch to put the lower control arm back on. It wouldn't line up about 1 mm and I had to get help from the local tire shop by having a guy move the arms w/ a pry bar while I screwed the bolt back in.
