Results 1 to 25 of 29
Thread: I really screwed up
    LX User Ace's Avatar
    1992 Honda Accord EX
    North Smithfield R.I
    I really screwed up
    Hey whats up
    yea has the title says I really screwed up today I kept my lights on at work so while trying to jump my car I crossed the positive and negative wires what could of this done my car will not even turn over and where should I looked I am so pissed off right now I have beeen drinking so much just trying to get over my stupidity don't mind any spelling LOL any feedbak would grealty be appreciated
    "Id Rather Be Blown Than Injected"
    Re: I really screwed up
    whats up any help I cannot belive I did thid I dont now where to start car wont even turn over
    May 2004
    '89 Honda Accord DX, 2 dr 5 spd, '87 Toyota Pickup, 22R 5 spd
    Puyallup, Washington
    ive done that wiring my little blue showoff headlight bulbs in my diamond cut headlights on my toyota pickup. burned my battery up, and my starter just clicked like crazy and never turned over. ive been having problems with this battery and the terminals for a long time. my battery leaked so a lot of corrosive battery acid starting eating my battery tie-down, and leaked down onto my windshield washer motor. it ate the seal so my washer fluid poured out in less than 5 min.
    buy a new battery. try push starting the car and see if it runs
    Thumbs up Re: I really screwed up
    Hey, I am just guessing and it may not help at all, but you may want to try just removing the battery cables for a few hours and see if something resets. May or may not work.
    James
    Quote Originally Posted by Ace
    Theres a main fuse located in the box under the hood. Hopefully that blew first and nothing had a melt down. Put a volt meter on the battery and report back and or get it tested. Sould be 12.7 volts fully charged. Tell them what you did cuz if you/they try and charge it it could blow and thats not pretty. My uncle had one blow on him and hes deaf in one ear now.
    yeah first check the main fuse, i did the same thing to my boss's daughter's car....after an hour i figured out that thats what it was. no biggie just check
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    Houston, Texas (Home of the Quicksilver project)
    I really don't think you are going to mess anything up by doing what you did. Did you try jumping it the correct way after that? If that does not turn it over, try connecting the positive cable directly to your starter (clamp it on the nut that the positive cable from your battery now connects to your starter), and connect the negative to a good ground on the engine block.
    Report back.
    "Feed their greed with your need for speed"
    Thanks I will look and report back to ya'll later on it . I was taking a look at pauls Manual at the electrical diagram and it looks like from the battery it goes directly into the under hood relay box now I am thinking that a charge must of caught in there and a fuse would of broke and saved it right??? I cant see it going past my main box. also I smelt a electrical smoke smell in my car. My head unit also doesn't turn on I think I may of fried that I will keep yall posted.
    probably a blown fuse, like mentioned above
    Quote Originally Posted by lackej1971
    James
    86-89 accords dont have any computers (unless its an lx-i or se-i) so there is nothing that could be reseted other than the clock, and radio, or the stuf you added yourself,like alarm and stuff
    yep, its the fuse. have you checked it?
    yea my battery fuse popped So I am thinking just swap that and I should be all set and if that popped that means it didn't hurt any more components of my engine. becaust that would of cut the circuit right?????
    Also My inline fuse to my subs popped
    SEi User
    Mar 2005
    swifts/sprints boosted
    Saskatoon
    Well a fuse will go when current is too high for it. Current tried to go there, so depending on how good your fuses are, they might not have blown immediately. Other damage is possible, but maybe not. Basically you turned your car into a 24V system.
    so all in all though I should be fine now if that fuse goes that would cause that car to not want to start?? And if it would of gone past that. wouldnt all my other fuses of popped.
    So really the next thing I should do is check my other fuses in my dash and make sure none of them popped right. beecause if not than that means it didn't spread
    i would check all the other ones while your at it, so then you wont be pissed when it doesnt start
    2.0Si User 3G Jester's Avatar
    98 Av6 3oh
    Sacramento, CA
    1)check and replace all fuses.
    2)bring battery to autozone, kragens,ect--they charge and test batteris for free
    if needs be buy a new batery, take some 3and1 oil and wipe down all your batter terminals and go from there.
    -Travis-
    luckily I have a optima battery 36 month warantey so I will swap that. I am pretty sure I will be all set after changing that fuse I am defintally replacing the battery my boy said that there was smoke coming out of it LOL so yea I am exchanging that.so we will see what that will do after that!!!!
    98 Av6 3oh
    Sacramento, CA
    whoite smoke usualy means head gasket...hopefully ur not burning coolant
    -Travis-
    i think he meant that the smoke was comming from the battery
    yea no smoke from the gasket it was from the battery had a awfull smell
    ok you probably did some damage,first replace your battery,then get your alternator tested,anytime you send current backwards through the car,you almost always fry the diodes in the alternator. contrary to what everyone says there is a computer in the car,even the carb cars have a computer,in both types it's under the drivers seat. with the ignition key on it should have one led on where the diagnostic leds are. if it doesn't have one on check the fuse,if thats not it,the computer has been fried. now i'm talking about a fuel injected car,the carbed car has no diagnostic leds. these cars have little electronic modules hidden all over the car,anyone of them could have been easily damaged,best thing to do is get that battery in and test everything electronic in the car, chances are your lights won't go up eithier,the control module is easily susceptible to damage. you might want to find a junk car and pull everything electronic that plugs in off of it. even if it's not fried yet the current spike will most likely have shortened it's life considerably. your ignition module inthe distributor is most likely fried,it's electronic and susceptible to damage from voltage spikes,if it won't start this is probably the culprit. i'm not trying to be a doomsday sayer,but this is the most likely scenario. i hope you got lucky,but even with the fuse by the time it blew it was probably too late,it's not to protect the electronics,but to keep the car from burning up. my suggestion is to get a couple of those felt washers that go under the terminals,then it's harder to mix them up. good luck
    Yea My headlights work so does my interior light and brake light work. I honestly think I got lucky because all this stuff does work and only my battery fuse popped none of my other fuses either I would think that it would of fried more than that more fuses would of poped I would think. we'll see
    SEi User
    Mar 2005
    Saskatoon
    Well lostforawhile thats like a purely worst case scenerio, I dont know if he turned alot of stuff on, but it sounds like he just increased the voltage to everything to 24, from 12. Because he ran 2 batteries in series. Im sure those things could happen, but its not a definate.
  1. Well my axle is screwed!!!
    By drewsleeperlxi in forum 3geez Accords
    Last Post: 05-12-2006, 12:30 PM
  2. Got screwed WHAT DO I DO!
    By my86dx4dr in forum Classic Honda Community Chat
    Last Post: 01-10-2006, 07:06 PM
  3. Heh, I screwed up!!!
    By 3gn86lxi in forum Classic Honda Community Chat
    Last Post: 05-26-2005, 08:44 AM
  4. something screwed up
    By jeffreygivens in forum Carburetor Tech
    Last Post: 09-14-2003, 11:45 AM
  5. well... im screwed
    By Chubs87Accord in forum Interior & Exterior Care
    Last Post: 07-16-2002, 05:38 PM
