Results 1 to 25 of 39
Thread: What is this yellow wire? (pics)
    LX User Shadowkat's Avatar
    1989 Accord LXi auto-->5 speed conversion 250,000 mi!!!! and still kickin!
    Champaign, IL & Chicago, IL
    Just finished a motor swap and auto to manual tranny swap, but there's this yellow wire that got disconnected during the swap and i don't know where it goes. The wire comes into the engine bay out of the firewall by the driver's side behind the air cleaner housing here:
    then it follows the firewall to the passenger side corner, then comes forward and ends near the fusebox/battery area here:
    any ideas as to what this wire is and where it should go would be helpful.
    TIA for any help you can give.
    The winter beater--I pulled the spoiler off a civic"
    Apr 2005
    1987 Honda LXI
    San Francisco
    Re: What is this yellow wire? (pics)
    Shadowkat, have you tried to trace the wire from under the carpet from the driver side. I know that there shouldn't be any wire that run through it unless you have an alarm or running a amp to the radio etc...
    That hole is where I run my amps through, before that it was covered by a black plug. I think that a yellow wire means either it is an ignition component or power source which was supposed to be red.
    Why Buy New when you can buy used
    1990 Honda Accord Ex 5spd.
    Knoxville, TN
    well it's not stock cause of hte crimped end.. so i'd imagine it's for something ETish on the car.
    "If you were paying attention DANIEL you'd know the Nintendo's pass threw everything!"
    - Col Jack O'Neal - Stargate sg-1.
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    Thats not a stock wire, some one put that there for a stereo, or alarm or some jerry rigged thing.............
    well, my family has owned the car since it was new, and there hasn't been anything jury rigged up, no alarm or stereo or anything. Don't be fooled by the crimpped end, that was done when we were taking the old engine out and got that wire caught, so it crimpped like that.
    1990/BMW/535iA
    New Orleans, LA
    As noted before, lift up the carpet inside and trace the wire. That's really the only way of knowing where it goes. It can almost be guaranteed that it is not stock though. Are you sure no extra options were installed on the car by the dealer? Fog lights perhaps? Just my $.02
    P.S.: Factory wiring is almost never one solid color...another indication that what you are looking at is probably not stock.
    3axap.
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    BTW that end on that wire aint stock........trust me honda doesn't use those on their cars....If they do they are black, I think thats a power wire......Just trace it and find out where it goes....
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Follow a wiring schematic to be sure. That crimped wire doesn't look something that is OEM.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Stupid double post.
    thats the plug right next to the cruise cable right? that should be a blank plug,honda doesn't run a wire through the middle of a plastic plug. if it was factory it would have a grommet or something in that hole. that plastic plug just has a hole right through the middle of it. thats not factory. I've never seen a factory honda wire that looked like that.
    Isn't yellow "On with Ignition"
    Or is that yellow with black stripe?
    how about this..... connect it to your battery and see if anything turns on, explodes, or burns....then it will tell you what its for lol
    That sounds like a brilliant idea! <----- that's me shooting the idea down, lol
    well, I don't think the dealer instaled anything extra other than an armrest. I suppose some mechanic that worked on the car found it necessary to run an extra wire from somewhere, but it seems unlikely, considering my dad, the buyer and driver of this car until a few years ago, doesn't remember anything like that. I'll just try and trace it like some of you guys suggested, I'll post if I find anything.
    On a different note, my horn doesn't work, and I don't understand the difference between clutch pedal free play and disengagement height(having never owned/worked on a manual until now, the manual's instructions are confusing me) yes i have searched on this subject, and yes i have found some info, nothing quite like I need yet, but i'm not done searching yet, but i figured since i had to start this thread anyways, i might as well use it.
    Okay well I just checked it out in the garage, and I believe the wire comes in behind the radio then over to the drivers side where it connects via wire connector(not factory for sure) to a red wire that in fact as others have mentioned goes under the carpet to the left corner of the car by the pedals. At this point it appears to have some sort of connector that connects with a wireing harness all the way in the front left bottom corner of the cabin, this, sa others have mentioned, does not look factory. The wire connector looks to be spliced into the harness then tapped over(but well done, like by a mechanic). So basically it's back to square one. My dad insists he knows nothing about it, and I'm stumped. so basically I'll get a pic up of where it connects in a few minutes. So if anyone know what this wire is doing, please help solve the mystery.
    1990/BMW/535iA
    New Orleans, LA
    Quote Originally Posted by Shadowkat
    Clutch freeplay is how much the pedal can travel before the cable becomes taught and you start feeling resistance(arm on transmission begins to move). Disengagement height is the height at which the clutch disengages and this is usually half way in the pedal traveling distance. Depending on clutch condition, this can deviate a bit. The harness in the lower front corner has many systems including door locks, rear lights, etc. If you can post a wire color that your non-factory wire is spliced to, we may be able to tell you what it is related to. I can't think of anything that would require such wiring though. By the sound of it, it isn't a solid wiring job either. Just my $.02
    3axap.
    well i can't really say what color it is, because it's inside a black cable. pics will b posted shortly
    okay, after the yellow wire comes into the cabin behind the readio and over to the driver's side it connects to a red wire like this:
    Then, the red wire goes under the carpet and splices into this wire bundle here:
    I believe this wire bundle is the same as this coiled wire. What the hell is this coiled wire?!!
    This is quite a mystery so any halp would be appreciated. And thanks for the info about clutch pedals.
    ok now i'm interested,you say nothing has ever been added to the car,are you sure? because i'm sure that coiled wire isn't factory eithier,what does it conect to? honda never puts extra wire in the cars,this must have gone to an amp or fog lights or something. you said your parents bought this car new? new from somebody else or new from the dealer. it almost looks like alarm wiring or stereo wiring. honda doesn't heat shrink eithier and what the yellow cut wire in the one picture? from where you said it came from the fuse box i'm almost certain thats for an old alarm,it probably fed power from the fuse box to the alarm harness which what you are looking at. i've worked on wiring in more hondas then i can count,and it's def not factory.
    SEi User Deadhead's Avatar
    Jul 2005
    Loveland, CO
    wow, that's a lot of coiled wire..... but why is it coiled? you'd think that if wire was run, that they would not leave a coil where you would bulge up the carpet....
    that's odd... good luck, but you may already be wired for an alarm, which is a plus
    that gauge of wire looks too small to be for a stereo.... then again, i've got some thick ass cable for my system (4 gauge).
    Quote Originally Posted by cke
    Does the car run?
    Are there any CELs?
    Any optional equipment not working?
    Yes/No/No? Yank the fucker out and forget it.
    Yes the car runs
    What's a CEL
    the horn and the cruise control don't work
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    Yes the car runs
    What's a CEL
    was the horn working before you did the swap? and worry about the cruise control later.
    but like cke said, if it runs fine without codes, yank that fucker out
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    That looks like wireing for an aftermarket cruise control setup, or an alarm, Or mabey even fog lights????
    we may have solved the mystery,as they say in england,it's for the telly. I think
    Yep, I think the mystery is solved, and it's all thanks to you lostforawhile for helping me, and my dad for suggesting that the wire could be for this old school car phone we have. I have yet to try using the wire to make that phone work in order to solve the mystery once and for all, but I'm 99.7% sure that the wires are all for the phone. Thanks to all who puttheir 2 cents in.
  1. Crazy yellow wire going to starter
    By moshbrandonmosh in forum 3geez Accords
    Last Post: 05-16-2011, 04:51 PM
  2. Black/Yellow Wire Goes Where?
    By firefighterwhite89 in forum EFI Tech
    Last Post: 02-07-2011, 07:33 PM
  3. Replies: 0
    Last Post: 12-30-2006, 09:10 PM
  4. Koni yellow (pics inside)
    By guaynabo89 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-23-2006, 03:52 PM
  5. Yellow Wire?
    By dosh8er in forum Classic Honda Community Chat
    Last Post: 05-10-2002, 04:19 PM
