1st problem
ok so for the past few weeks my freaking reverse gear has been grinding up every time i try to back out of my driveay. it mostly happens when i first turn on the car. what i do to fix it is put it in first move the car a bit then put it back into reverse. no grinding then. what could be my prob? any suggestions? i have actually not changed my tranny fluid uh...ever. but i have only had the thing 6 mos. i know i know i should have done an overhaul on the damn fluids but...eh it slipped my mind. well actually i did almost everything else besides the tranny.
2nd problem
ok i think my damn water pump is going out.that sucks man. anyway here are the "symptoms" maybe its something else. ok so when i bought the car it would overheat like a freaking female rabbit's vagina. so i changed the radiator, because of a crack by the neck of the cap, as well as changed all the hoses. well i dont overheat (except once at one of our meets lol) anymore and the problem was gone. after the overheating problem at the meet, i keep getting the same burnt coolant smell you get when you have a leak. i had the cars hoses pressure tested and well no leaks. so i looked in my engine bay today after work (6am) and noticed a drop of burnt coolant on top of the tranny towards the top. it was right under one of the hoses that were changed. i touched it and looked with my ultrabright and handy $300 dollar flashlight (provided by work)
and nothing. so is this my water pump? or am completely off? is my water pump even on that side of the engine? lol
