Results 1 to 18 of 18
Thread: Headlights wont go down?
    88 honda accord
    toledo, ohio
    the other day after jump starting my car i found that my headlights wont go down. they go on and off fine but they stay up. also my dash lights arent working and the dimmer switch isnt lit up, actually im not sure if their was even a light on the switch but still curious y they wont go down.
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Re: Headlights wont go down?
    you may have the button pressed to open them. then again, if your dimmer switch isnt lit up, it may have become unseated. try replugging the whole switch.
    '89 SE-i Coupe
    Awaiting Garage
    disconnect your battery (asuming its good now) leave it off for about 5 mins then recconect it maybe. if that dont work check your fuses
    88 honda accord
    toledo, ohio
    i have an lx-i and it has the light-dimmer-defrost switch altogether and the defrost switch works but the other 2 dont seem to work. ill check the other fuses and try disconnecting the battery.
    thanks
    89 Accord LX-I
    Wagoner, Ok
    there should be some fuses under the hood near the battery...two fuses in there operate the Left and Right Retractors...
    May 2003
    88 Accord LX 88 Accord LXi
    Quote Originally Posted by zacritz929
    thanks
    That is the dimmer, defrost, and headlight retractor switchs. Check that the headlight retractor switch isn't pushed in. If it is your headlights will not go down.
    Do you mean 2 of the switchs aren't lighting up. If so pull the switch cluster out. They each have light bulbs in them. Maybe the bulbs are burnt out.
    Jun 2001
    Boston MA
    you might want to check the switch itself. the acrtual switch is a relay. when installing my gauges i unpluged my switch and when i turned on my lights the filped up and stayed up when i shut the lights off. plus my interior dim lights did not work at all
    S.Q.U.A.D. Engineering
    www.squadengineering.com
    did you just buy the car? when i bought it the moron that had it before hit the the right front corner of the car and the actual arm that held the light was bent, therefore it made the lights stay up. of course that was probably just in my situation.
    but after i fixed it with another light assembly from the jy, i had to change the fuses, cuz they were out, and the connector was unplugged. check to see if your connector is unplugged, has any corrosion, or even if it has any tears or cut all together. other than that, check the relay for the lights.
    for your back lights not turning on, it may be just a simple fix of replacing the bulbs. i had to replace some on my car too. just go to autozone or your nearest auto parts store. they have them there in stock most of the time. or it could also be that they wire for the lights on the switches is unplugged, cut or whatever else.
    these are the things you may want to look for.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Nevermind. Sounds like electrical trouble shooting.
    SEi User 3gn86lxi's Avatar
    Jul 2004
    wa
    I had the similar problem after I did my HID conversion. And it actually turned out to be a loose wire going into the main fuse block under the hood.
    Try that too.
    ~Ryan~
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    I had this happen once, I think it was a fuse issue.
    I love the flip up light switch, I think it's the best feature of the 3G.
    to tell you the truth i think its a bit useless....lol
    in the owner's manual that came with my car it says that its for poping the lights up just in case the other switch doesnt work. does that mean that they're wired on a different system? the two switches i mean
    88 honda accord
    toledo, ohio
    ok i checked all of the fuses and theyre all fine even the fuses under the hood. when i said that the switches arent lightin up i meant that i dont think they are getting power. how exactly do you get the switch cluster out???
    '88 accord lx-i sold for $10
    2drSE-i's Avatar
    Oklahoma City
    you can pop it out with a small flathead screwdriver towards the bottom of the switch. there are three connections on the back of this switch, the middle one is blue and the two on the sides are yellow, but they are shaped very differently, so you can easily tell which is which.
    '89 SE-i Coupe
    Awaiting Garage
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Edit.
    Nevermind. Was going to say test the motor for power & work your way back. But if the light isn't working on the switch, then that is probably the case.
    DX User ckhaing's Avatar
    Sep 2022
    1988 Accord DX Hatchback
    CA
    Quote Originally Posted by A20A1 View Post
    I got that problem, not retracting after the headlight was off, unable to close manually under hood. Turned out I totally forgot there was that "flip up switch" that was accidentally switched on. Thanks
    LX User RI86DX's Avatar
    Jul 2022
    1986 Honda Accord DX, A20A1 4SPD H4F4 AT
    Rhode Island
    Dude, this thread is so old Bush Jr. was president and the person you replied to might have changed sexes (if not, they're probably the sole actual woman on planet earth with that much feedback carb knowledge) and went AWOL, besides massively downgrading to a Cobalt.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    It doesn't really matter the post was necroed, some of the most relevant posts were made in the first 5 years of the forum. It's not like they are expecting an answer from the op. If the necro is a problem old blue would probably come delete the reply.
    And I don't think that was very appropriate... A20A1 was active until 2015 and I'm pretty sure is an actual woman. They had the accord for 15 years or more and it was already that old when the forum was created, some cars just don't last forever when they're actually used.
  1. what do i need to do my headlights wont go down .....
    By nomocars23 in forum Interior & Exterior Care
    Last Post: 03-31-2008, 10:05 PM
  2. headlights wont open or close
    By import racer in forum 3geez Accords
    Last Post: 07-24-2007, 07:44 PM
  3. headlights wont work
    By RiceIniside in forum 3geez Accords
    Last Post: 12-12-2005, 06:48 PM
  4. Headlights come on and go up but wont come down...?
    By SmokingTires in forum 3geez Accords
    Last Post: 08-25-2005, 08:31 PM
  5. Headlights wont go down
    By TwtrLX in forum 3geez Accords
    Last Post: 02-13-2003, 03:05 PM
