Results 1 to 25 of 26
Thread: H22 Cam Gear on A20?
    LX User Swap_File's Avatar
    Manual 89 Se-i Accord
    Minnesota
    The A20 and H22 both have 42 teeth and both have the same tooth pattern, as TWOLOUDNPROUD showed in this thread:
    H22 belt on A20 gear.
    Anyone happen to have an H22 gear sitting around and want to see if it would work on the A20? It's just a matter of making sure that the cam gear fits on the cam shaft, and that the offset for the gear is similar. If it fits we could have a cheap source for adjustable cam gears.
    SEi User
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    Re: H22 Cam Gear on A20?
    wow, i WOULD like to help as much as i can, but unfortunately i cant cause i dont have an H22 cam gear nor do i have the extra cam... wouldnt it be easier to measure the offset of both cam gears, and then pull a cam out of a junker to test fit?
    Minnesota
    I would like to just pull the parts out of a junkyard car for measuring, but no where around here has H22 engines on hand.
    I do have an extra stock A20 cam gear sitting around, I can take measurements from that and post it later.
    LXi User b8er's Avatar
    1987 Ex-i 89 SE-i
    Kelowna, British Columbia
    wouldnt the awsner for this question be in the thread posted above?
    -Who needs horse power when you got icy roads and bald tires
    -To drift a car is to create reckless art
    Idaho
    Why would they be the same size gears? Honestly...
    Minnesota
    The last thread ended ended with no conclusion on the matter. It was just assumed that someone would try it, and report back. No one did. I would try it myself, but I have been unable to find a gear at a local junkyard.
    I did not want to dig up the old thread because it was more about the phrenology cam gears that were on ebay than the possibility of using an H22 gear.
    Bottom line is, we won't know if a H22 cam gear will work until someone tries it, or at least gets measurements (offset and cam diameter) from an H22 cam gear.
    Accord of the Year - 2008
    TWOLOUDNPROUD's Avatar
    May 2003
    H22 Cam Gear >http://cgi.ebay.com/ebaymotors/FIDAN...QQcmdZViewItem For $89.00 Free Shipping
    Minnesota
    Yeah, I have seen the adjustable cam gears available on ebay, but I really do not want to spend that kind of money if I do not know if it is going to work. All that is needed for testing and measurements are the OEM gears. I never see them for sale online because I guess most people consider them worthless.
    Nov 2002
    Ridin Dirty in New York
    wasnt there gonna be another group buy on the golden eagle cam gears?
    it was stopped remember? we all got gipped! :cry:
    what if someone finds a stock cam hear for the h22 on ebay or any other website for that matter. if i find one for a reasonable price will someone want to buy it? cuz if thats the case ill spend all the 8 hours that i have in this stupid office looking for one lol
    sorry that im going to ask a noob question....im going to the junk yard tomorrow and wut year and model of car is the H22 engine for...everything is 50% off so it might not hurt
    Minnesota
    I was watching ebay for a while, but no one had them for sale. One guy had some for sale for $10 ($15 shipped) on Honda-Tech. but he was out by the time I talked to him.
    According to Wikipedia the 1993 - 2001 USDM Prelude should have the H22 engine. It's the only other Honda engine to have 42 tooth cam gears.
    snoopyloopy's Avatar
    Killa Cali
    doesn't the 99-01 prelude have an h22 too? and what about the h23? does it use the same cam gear? and if you're lucky, you can find an h22 swapped into other cars too.
    Minnesota
    Quote Originally Posted by snoopyloopy
    You caught me as I was editing my post.
    The H23 cam gear is different than the H22, it has less teeth. I forget the exact count.
    Edit: H23 cam gears have 34 teeth.
    SEi User racerx's Avatar
    May 2003
    87 Honda Accord DX
    Colorado Springs
    H22 came in the:
    92-96 Prelude (4th gen) VTEC model, 190hp
    97-01 Prelude (5th gen) any model
    in 97, 195hp
    98-01, 200hp
    JDM H22A in the Type-S model produced between 97-01, 220hp.
    www.stein-photo.com
    born to XLR8
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    https://www.3geez.com/forum/showthread.php?t=47130
    Phrenology's thread.
    You should honestly look into a SOHC engine and use their crank gear as well to keep the diameters matched up.
    Minnesota
    I am not too worried about the outer diameter of the H22 cam gear. It should match up perfectly with the A20. They both have 42 teeth, and since the belts teeth spacing match up, they would have to have the same outer diameter.
    And I had no luck finding any other crank timing gears that would fit the A20. (over here). There are still blocks left to check, but the search was not going well.
    A20A1's Avatar
    Sep 2001
    Well smaller diameter and less teeth would have the same belt teeth spacing as a larger diameter with more teeth, thats why I didn't feel that image helped any.
    but as you said both are 42 teeth so I guess the diameter would be the same.
    You also want to consider the construction of the cam gear beyond how cheap they are... you don't want to buy something that will fall apart or slip.
    carotman's Avatar
    Montreal South Shore
    I have an AEM H22A gear here. It's not the same diameter as the A20A. I'll post pictures.
    Too bad.
    I need these parts!
    SEi User
    Jun 2005
    Edmonton AB
    Too bad.
    if all the tooths are spaced out properly, and the belts will fit around it properly, wouldnt it work? i figured the tooth count was the only thing that really mattered much
    A20A1's Avatar
    Sep 2001
    Oh well...
    What about the camshaft inlet diameter?
    carotman's Avatar
    I'll check the cam diameter. I got this camgear by error so I'm kinda stuck with it.
    I need these parts!
    were talking intake or exhaust cam? I d assume the h22 is a same but you never no.
    SEi User ZackieDarko's Avatar
    dun dun dun what happend with this?
    Quote Originally Posted by ZackieDarko
    the guy who was going to do the cam gear backed out from the group buy...i guess you have to spend your money and get an adjustable eagle cam
  1. GE Cam Gear
    By Vanilla Sky in forum For Sale
    Last Post: 12-12-2010, 09:52 PM
  2. Gear
    By NC 85 3Door in forum 2geez Accords
    Last Post: 07-22-2009, 06:45 AM
  3. WTB: GE Cam Gear.
    By markmdz89hatch in forum Wanted
    Last Post: 03-05-2009, 07:50 AM
  4. 100 in 4th gear
    By hondarider88 in forum Performance
    Last Post: 01-19-2003, 12:51 PM
  5. adj. cam gear pic
    By guaynabo89 in forum Classic Honda Pics & Videos
    Last Post: 07-05-2002, 12:35 PM
