Results 1 to 21 of 21
Thread: Cut my springs
    Mar 2006
    1989 accord lx
    surrey bc
    Cut my springs
    Well I did it I cut the spring two coils on front and two on back droped car about 1.4" so it does work rides good still cut the springs off the bottom with grinder while still on car just jacked it up put on spring compresser and cut took about 15 min per looks good and works well
    Re: Cut my springs
    ouch
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    Re: Cut my springs
    im sorry.
    2.0Si User 3G Jester's Avatar
    98 Av6 3oh
    Sacramento, CA
    Re: Cut my springs
    HA! your shocks are PHUCKED now buddy.
    find your friedns and punch themm in the teeth for either a) putting shitty ideas in your head or B) not advising you against that.
    -Travis-
    LX User Mars's Avatar
    Feb 2005
    1989 LXi Coupe
    Dallas Tx
    Re: Cut my springs
    man dude, cutting springs is a bad idea. it completely changes the property of the springs.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    Re: Cut my springs
    ROFL. you guys. cutting your springs technically does change the properties of the springs, but people have been doing that since your parents were kids. Its a cheap easy way to lower your car. sure, its not good on your suspension, but i'm betting he's not going for competetive auto crossing, so it'll do just fine. Its not going to eat up his struts any worse than a cheap set of coilovers off ebay would.
    Nothin' 2 Old Racing
    Re: Cut my springs
    Quote Originally Posted by NXRacer
    for reels? i want to cut mine since my new struts made my car higher but then a set of dropzone springs are only 80 bucks and they will lower it 2.25 inches...i have not done all my research but if i lower my car should i be worried about camber wear?
    Re: Cut my springs
    id like to know this as well? how far can u go before it efects the camber.
    Vanilla Sky's Avatar
    1999 Penalty Box
    Re: Cut my springs
    congrats on your now dangerous ride.
    i have several sets of springs i can send you.
    and yeah, caleb, people have been doing this forever. they have also started wars and commited suicide forever. you don't see me joining in.
    while yeah, new springs cost a few bucks, you can get them cheap online. i know you should be using new struts with them, too, but you can get away without it for a while.
    the reason i'm so against cut coils is that your springs will never seat in thier perches properly again, giving you a shitty ride and posing serious danger if the spring happens to slip (see "car in brick wall" for references).
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    Re: Cut my springs
    you can also use some cheap springs for a 90-93 accord? theyre on ebay all the time, i thin those are better than cut springs
    -Gio
    My E85 Turbo Build
    5280FEST
    Re: Cut my springs
    Quote Originally Posted by gfrg88
    Do they sit lower than the stock coils in our models?
    Re: Cut my springs
    did you even meassure where you cut them? i know that some people use a piece of string so they cut it at the same location.
    i still say ouch.
    A Mile High.
    Re: Cut my springs
    i think they are the same?
    -Gio
    My E85 Turbo Build
    5280FEST
    SEi User Acid X's Avatar
    Apr 2005
    Azusa, CA - Los Ang. County
    Re: Cut my springs
    I have a 2.25" drop with the Dropzone Springs.. The camber is around 1.7 degrees all around. I haven't noticed any bad tire wear, just be sure to get an alignment after. Toe is what really eats up your tires.
    I know i just rotated my tires and the inner edge of my rears were worn alot, but i think that might have been because i was rolling on really low tire pressure for a while.
    Also note that i have 16" rims with 205/45 tires, so that will also make a worse wear than stock tires (i think, just because they are wider)
    90 CRX
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Re: Cut my springs
    Quote Originally Posted by Acid X
    Specs say 1º is the max. You're a little over so you'll wear a little more but no sweat.
    LXi User b8er's Avatar
    1987 Ex-i 89 SE-i
    Kelowna, British Columbia
    Re: Cut my springs
    from what iv read around, anything lower then a 2inch drop is gonna need a camber kit, just like AcidX said its alwasy a great idea to have an alignemnt done anytime anything major with the suspension has be played with. i realixe ppl have ben cutting springs for years and years but it still seems a little to retro for me, on an older 30's rat rod era car i see it no prob but i dunno, mabye its just me, aha,
    got any pics of the car lowerd now?
    1988/Honda/Accord
    Oregon
    Re: Cut my springs
    yeah man after you cut springs your tires will start to wear really bad on one side of your tires if you do not get a camber kit i dropped my quit a bit and i dont have a camber kit and if i dont get one soon i will be paying for tires every couple of months. and with 100 dollar a piece tires that will add up fast. Get a real suspension lowering kit and a camber kit, and do it right.
    Mar 2006
    1989 accord lx
    surrey bc
    Re: Cut my springs
    the camber is still ok long as i dont drop any more the front cuts worked well the back is not so great the springs dont line up unless you take them apart to cut them but looks good
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    Re: Cut my springs
    technically, if you drop your car at all you need a camber kit.
    its highly suggested to get one if you go lower than 1.5 inches.
    I cannot stress enough what acid-x said. I had my car dropped over 3" and i had VERY little tire wear on the inside due to the fact that right after i dropped it i had a body shop do a toe alignment on it. Every shop will tell you you can't adjust the camber, but just tell them thats ok, all you want is a toe adjustment.
    Having bad toe will eat your tires in a matter of weeks. Fixing that so all you have is negative camber and you'll be golden. Of course, a camber kit is highly suggested, but not an absolute must unless you're going for auto-x. But keep in mind, your tires WILL wear faster than it would at stock heighth. Even if you have a camber kit.
    AZmike's Avatar
    Tucson, Arizona
    Re: Cut my springs
    Care to elaborate?
    Mike
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    Re: Cut my springs
    i've yet to see or hear of a camber kit that fixed a camber issue 100%. when you add custom suspension stuff, you throw out the factory specs and its hard to get it back.
  1. How to on how to cut springs on a 3rd gen
    By .:dutchtuner:. in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-14-2010, 04:34 PM
  2. Springs!
    By GTRSkyline43 in forum Wanted
    Last Post: 07-18-2009, 11:50 AM
  3. H & R springs???
    By bradSA138 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-24-2006, 03:44 PM
  4. Springs
    By SDracerBOY in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-16-2003, 10:55 AM
  5. springs???
    By almightyaccord in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-11-2002, 01:35 AM
