Results 1 to 6 of 6
Thread: Painting Interior parts
    1988 Accord LX
    Ontario
    I recently painted the the interior of my car everything went good other then the arm rests in my car when it is sunny out they get sticky and sometimes a little bit of the paint comes off .
    Is there a quik fix for this or do i have to take them out, sand them and repaint them again.
    Thanx
    Re: Painting Interior parts
    uh...pics? and please dont tell me u used regular paint? youre supposed to use that fusion stuff.
    1988 Accord LX
    Ontario
    Yes i did use the right paint, and it was the fusion stuff. Every thing else turned out perfect if i can get a cam i will take pics
    only the arm wrests get sticky
    thats wierd cause the arm rest dont geta hole lot of light but u may want to pull them a try a sand and respray just to see if it happens again and im with monkey id like to see some pics
    well i sanded all my plastic down with 400 grit sandpaper just to smoth down any scratches and stuff. then i used a plastic promoter that took 40 mins to flash dry and then i hit it with duplicolor paint that is for vinyl and plastic. so far i could tell that i did not spray it right so i will spray it and take some pics
    i've found that Krylon Fusion does not do well on soft plastic, rubber, or vinal. i had the same problem. as you said, everything else comes out great. i'd say try and match the color you did with some vinal/fabric paint. i'd recommend Duplicolor Vinal/Fabric dye that you can buy at most auto parts stores unless you want to go and spend $20+ a can of that expensive stuff they sell in magazines. using the adhesion promoter works great too if you wanna use the fusion.
  1. My take on a "Painting Interior Parts" writeup
    By maxsideburn in forum Interior & Exterior Care
    Last Post: 04-10-2006, 06:03 AM
  2. InterIOr Painting
    By AccordArizona89 in forum Interior & Exterior Care
    Last Post: 08-24-2003, 08:26 PM
  3. painting my interior
    By 89lx in forum Interior & Exterior Care
    Last Post: 06-23-2003, 10:24 PM
  4. Painting Interior
    By slammedLXI in forum Interior & Exterior Care
    Last Post: 12-16-2002, 12:52 AM
  5. interior painting possible?
    By 89blackdx in forum Interior & Exterior Care
    Last Post: 07-29-2002, 11:01 AM
