Results 26 to 50 of 99
Thread: My Adventures With Seafoam
    Re: My Adventures With Seafoam
    no i think this is just unique to me. i honestly think this is just an exhaust leak.
    1989 Accord LXI Coupe
    Santa Barbara, CA
    oh, aight, so when i do this... how did you exactly do it? u just poured in 1/3 bottle under the oil cap???? did you do anything else? or just that?
    V12 Supercharged Toyota Accord
    no 1/3 goes through the brake booster. you have to feed it slowly then drown it till the engine dies.
    after it turns off, pour 1/3 of it through the oil dip stick lil pipe thing.
    then the rest into the gas tank. it says to let it sit for 15 mins but i let it sit for almost an hour. some guys here let it sit 24 hours before they do anything. so its up to you really.
    Santa Barbara, CA
    oh, wow. aight.
    lol. newbish q, where is the break booster. lol. ( i know where the dip stick and gas tank are. lol.)
    its the biggest hose that goes from the IM to the uh...brake booster. looks like a lil plastic can thing. its really not hard to miss
    Vanilla Sky's Avatar
    1999 Penalty Box
    oddball question, but do you still hve your cat? i know you're in CA, but that doesn't really mean anything. my truck did the same thing after seafoam. it clogged my cat and it blew out. now i have a horrible leaky exhaust right before my cat. it still flows some, but not nearly as well as it should. that's what i'd check.
    yes i do still have a cat. i was thinking something along the same lines as a clogged cat. but even if it is...its ok im going to be installing my new exhaust hopefully soon. like within the next month or so. i already have a muffler, the headers, just need a cat and of course the piping. oh and im going with a high flow
  8. #33
    2ndGenGuy
    Guest
    I don't think I'd ever put this stuff in my car. Why do you need to "clean" out your engine when they already run 300,000+ miles without any problems? I think that if this stuff really worked, then the manufacturers would be pushing people to run it in thier engines and doing it during service intervals. It sounds like it would be a cheap, easy way to improve the reliability of a car. So if that were true, why wouldn't the manufacturers suggest it?
  9. #34
    i guess cuz its been a secret since 1942. i have seen it featured on two guys garage on the speed channel. so i know other people endorse it
  10. #35
    SEi User Acid X's Avatar
    Apr 2005
    Azusa, CA - Los Ang. County
    I forgot to mention, check your oxygen sensors. Matt says he was having the same sort of problem when he painted his headers and then installed them. He got paint inside the header and it caused the oxygen sensors to get messed up..
    What he did was take the oxygen sensors out, use some lemon juice (from a real lemon) on them (the acids help clear out the sensor i guess) and let them dry out and re install them...
    or buy new ones.
    90 CRX
  11. #36
    May 2003
    05 Legacy GT 87/accord/lx (rip)
    boston
    Just fed my 5G a can of the good stuff. After a bit of smoking, it revs like a bike now. F'ing awesome. I wonder how long it will take for the check engine light to go off...
  12. #37
    lol ^
    your check engine light came on? wtf....check for some codes, you might have clogged 02 sensors...i know i did
  13. #38
    man it seems like everybody who uses this on our cars has problems afterward lol
  14. #39
    well it tells you right on the bottle not to use it on cars that have over 100k mi on it
  15. #40
    Yeah you have to be carefull using this stuff. It did miracles to my old engine but it also clogged my PCV Valve...
    Causing my pan gasket and valve cover gasket to start leaking....
  16. #41
    LXi User Jasonf860's Avatar
    Jul 2006
    89 Accord lx, 94 BMW 325i
    It should be noted that Seafoam is not recomended to be used on engines with over 150k on the clock... I'd say that is a lot of us!
  17. #42
    my boss has had over 30 cars in his lifetime....i showed him the stuff and he told me not to put it in the oil....he told me at best put it on the gas tank.....i did feel a deference ....i put it the day b4 the SF meet and now the car reves faster. it also bumped my MPG to like 35 but the next fill it i only got 32mpg...anyways ....i dont have a problem...i might put some on my dx to see if it passes smog check.
    I wonder if this will work for you Messy
    http://www.blueskycleanair.com/pass....TOKEN=16410948
  19. #44
    snoopyloopy's Avatar
    Killa Cali
    hmm...so theoritically, we could "start" a "company" and "manufacture" crap for our cars like cai and get a smog legal sticker on them.
  20. #45
    May 2003
    boston
    Most likely I did. It's time to replace them anyway, so I ordered a pair of NGK ones. I'll replace the pcv valve, spark plugs and the fuel filter at the same time for good measure. My goal is to get 30mpg while revving her up to 5k more often than not.
  21. #46
    lol i know.. but you said yourself "thats a lie" at the top of page two of this thread
  22. #47
    LXi User DDRaptor's Avatar
    1988 Honda Accord LX
    Bronx, NY
    So from what i have read seafoam is great but you have to make sure you change all the filters, on the lines that your running it trough. and maybe even taking your exhaust off until it goes through your system. cause i have a stock cat so i will be betting that it will happen to me. ANother question if you putting in the brake booster hose do you have to bleed the brakes later, just a newb question.
    89LX or SE-i(yeah right)
  23. #48
    Quote Originally Posted by DDRaptor
    It's get suck thru the intake by using the booster hose so you dont have to bleed the brakes
  24. #49
    yeah you just unplug the hose FROM the brake booster. leave it plugged into the intake mani and let it suck it up. i liked how the engine sounds like its drinking it lol
  25. #50
    Bronx, NY
    dude, i have to try this. I usally pump some Gunk 5 minute motor flush before the oil change, but maybe a bottle seafoam will do a much better job.
    i will have to do this sometime soon. but i will have to have 2 new fuel filters, an oil change, oil filter. etc. cause i see this thing is just super cleaner.
  1. Seafoam vid!!!!!!! ;D
    By gfrg88 in forum Classic Preludes
    Last Post: 04-05-2011, 07:36 PM
  2. seafoam question
    By CzEcHy in forum 3geez Accords
    Last Post: 09-07-2010, 03:06 PM
  3. Seafoam with 260k?
    By dmbshu in forum EFI Tech
    Last Post: 09-02-2007, 09:53 AM
  4. Adventures in SEAFOAM
    By A20A1 in forum Classic Honda Community Chat
    Last Post: 05-17-2006, 02:52 PM
  5. Seafoam
    By Micah 89LXi in forum Classic Honda Community Chat
    Last Post: 02-01-2006, 09:59 PM
