Congratulations to 88LXi68 for winning AOM July 06!
88LXi68
Exterior
CF Hood
90-93 Integra Spoiler
Body matched moldings
JDM corners
Se-i alloys (currently)
Interior
90-93 Integra Headrets
84-87 Prelude shift knob and boot
autometer volt and EGT gauge
SE-i center console and SE-I cupholders
Suspension and Brakes
Ground Control Coil Overs
Koni Special Struts (Reds) all around
84-87 Front Upper Prelude Arms
Ingalls Rear Camber Kits
Addco Front and Rear Sway Bars
DC Sport upper strut bar
88TurboAccord rear strut bar
Se-I rear disc conversion
Brembo Cross Drilled and Slotted Front & Rear Rotors
Techna Fit braided lines
Axxis Metal Master Pads
Engine
LS/VTEC Swap
B18A1 Block
Arias 11:1 Pistons
bored .10over
Eagle Rods
new bearings
honed
balanced
clearances checked
Place Racing Mounts
B16A2 Head
CTR Cams
Fererra oversized valves
ITR Valve Springs and Retainers
Port and Polished
3angle valve job
ITR Intake Manifold w/ ITR Throttle Body
JDM 4-1 Itr Exhaust Manifold w/ 2.5" outlet
AEM Fuel Rail
B&M Fuel Pressure Regulator
Short Ram Intake
2.25 Exhaust no cat upgrading to 2.5
Drivetrain
LS Integra S1 tranny
ACT Extreme Pressure Plate
ACT Steet Disc
SCT Streetlite flywheel
Place Racing Axles
Pacesetter 84-87 Prelude Shortthrow shifter
ECU & Electronics
OBD-0 PR3 chipped
Apexi VAFC
MSD SCI-L
MSD Blaster SS Coi
OEM Honda Wires
Place Racing Wire Harness
Removed A/C and P/S
Audio
Alpine 3CD in dash changer
Alpine 6CD in trunk changer
MB Quart 5.25 fronts
Mb Quart 6x9 rears
Zapco Symblink
Zapco 360W Amp
vid of car
