its not hard really.
1. remove the pipe that connects to the filter box and the resonator on the fender. (the one with the black sticker) to do this you simply use some plyers to pinch the clamp to get it off.
2. undo the screws fromt he clamps that connect the u bend to the tb and remove the u bend
3. to remove the air box, simply unclamp the cover and remove. take the filter out. i belive there is a total of two screws holding that thing down. it might be three but they are very easy to spot (both on top) and are 10mm like the rest of the bolts used to put together this piece of metal we call our baby.
4. the rubber piece that connects the longer of the pipes to the resonator is simple to remove...just pull on it.
5. the resonator has two bolts holding it on that are accesible from the bottom of the car. you may need to jack it up just in case you have a huge head like i do
. to get to it you dont really need to remove the whole wheel well lining...just pull it back to get in there. to do that there is one screw holding it to the bumper (phillips head) and a bolt at the bottom of the car (10mm). then be careful when pulling the clips that hold the thing in place, you dont want to break them. you can simply put a flat head screw driver in between the head of the clip and the base...pry it off gently and presto! you shouldnt have to remove more than three of four to be able to pull it off. then just remove the resonator from the bottom of the car and youre set! oh and by the way the resonator looks like a black box with a pin hole on it
see completly easy! if i missed anything someone let me know so i can correct it. if not then....thre ya go!
have fun
