Results 1 to 24 of 24
Thread: Fluids Thread
    LXi User DDRaptor's Avatar
    1988 Honda Accord LX
    Bronx, NY
    Fluids Thread
    I have searched and searched.
    But I want to make a thread where all you guys chip as to what fluids you guys run in your cars.
    Engine Oil: Castrol Syntec 5-30 (my manual had 5-30 listed)
    --I use gunk Engine Cleaner when i do oil changes
    --And i also use restore 4 cylinder formula
    Coolant: Prestone and only prestone no water.
    --(i even use it in my water cooling kit in my pc )
    Transsmisson: Coastal Dexron III ATF (boring auto)
    --Have'nt found any better.
    Brake Fluid: regular DOT3
    --Have'nt found any specific brands.
    Power Steering: ???
    Washer FLuid: Valucraft 2.99 bottle with rain-x in it.
    I just wanna get feedback from the masses to see what you guys are running.
    89LX or SE-i(yeah right)
    Nov 2002
    Ridin Dirty in New York
    Re: Fluids Thread
    Engine Oil: 10w-30 or 20w50 either mobil 1, mobil or valvoline
    Coolant: Honda coolant
    Transsmisson: Either honda MTF or gm syncromesh friction modified
    Brake Fluid: honda
    Power Steering: honda
    Washer FLuid: cheapest i can find
    Re: Fluids Thread
    how well does the syncromesh mesh work i have to replace my whole tranny at the end of the month and its a 5 speed i just wan tsome thing that will make the new tranny shift smooth and last for a long time
    Re: Fluids Thread
    Quote Originally Posted by DDRaptor
    Power Steering: ???
    Engine oil: 5w30(i dont knoe wut brand but its wutever mazda uses since i get it for free)
    coolent: shell type(like i said i get it free) i add water to it tho.
    trans:havent changed the oil yet. but i would go with like 10w30? for manual
    brake fluid:i have to put in my SE-i brakes and SS lines....then im flushing and converting to DOT4...more high performance
    Power sterring: Honda brand
    washer fluid: dollar store type...cant beat a buck for a gal and it work alright also.
    gas 87 oct
    Re: Fluids Thread
    all i know about mine is
    engine oil: (ill check tomorrow)
    coolant: water
    fuel: unleaded 91
    Bronx, NY
    Re: Fluids Thread
    water. damn you and your temprate weather, it gets plenty below freezing here.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Re: Fluids Thread
    mobil 1 - 20w50 15w40
    valvoline
    B&M trick shift in auto + mobil ATF
    Some redish colored coolant... not sure what company that was.
    LX User Tailfin's Avatar
    1990 Cadillac Fleetwood
    New York...work while it's still warm...
    Re: Fluids Thread
    Eeep...Umm, this is probably subject to debate, but I would not advise using any oil additive, water only, or red coolant... Oil additives are mostly snake oils...most of the companies (STP, Castrol, etc...) have been through lawsuits to boot. They often brag of anti-friction additives, like PTFE (Polytetraflouroethylene), which is just teflon. Sure, great idea, except that teflon is a solid, which can clog filters, build up/damage main bearings, etc... Others, like Lucas, supposedly coat better, but they don't show you in their little gear demonstration that when it gets up to high speed, it "coats" better by getting air into the oil, and foaming up causing all sorts of inferior mess. Oils were needing help a long time ago, but the technology has come a long way, and most companies now have a blend of additives already in the oil. It's like a cake recipe... Putting the right amount of eggs in is good, but putting extra eggs in does not give you a good end result.
    Running just water isn't a great idea because the antifreeze has anti-corrosive properties. I had a slow leak in my car, so until I got to fixing it, I poured water in this summer. Brand new radiator, and I already saw brown in it.
    The red coolant is "dex cool," which is supposedly superior stuff, but I've heard that it can be harsh on seals and such, which is not cool :-P. I'm not positive on that one, but I don't see what you're getting that the green stuff doesn't give you.
    Apr 2006
    2007 Cobalt LT Coupe
    Moose Jaw, Saskatchewan
    Re: Fluids Thread
    Engine oil: 5W-30 Quaker State High Mileage
    coolant: The cheap Canadian Tire stuff
    transmission Fluid: Honda Manual Trans. Fluid
    brake fluid: DOT 3
    Power sterring: Normal oil (it leaks somethimes)
    DX User mavric240's Avatar
    Sep 2006
    1989 Honda Accord DX 2.0c Auto
    Dayton
    Re: Fluids Thread
    OK alot of information here but nothing really showing what Honda specs are. Most just opinions of what someone uses or is using. And one thing that has me puzzled is, who would ever think about using Dex-Cool in anything. Its crap in the GM's so what makes you think it would be any better in your Honda. A green fifty/fifty mix is the best overall for most climates. Change it once a year so that the mix does not turn corrosive. If you have the need to lower the fluid temp then use Royle Purple's Purple Ice or Red-line's Water Wetter and follow the instructions on the bottle to achieve the desired effect. Water boils and freezes faster alone. When mixed with green anti-freeze(EGly) you get a chemical reaction that reduces the fluid temp and keeps it from boiling and freezing. Basic chemistry!
    WOW rules
    Sep 2003
    '89 LX
    Virginia
    Re: Fluids Thread
    Engine Oil: 5W-30(as recommended in manual) Mobil Clean 5000
    Coolant: 50/50 mix of whatever I see
    Transmission Fluid: Regular 10W-30 Motor Oil (recommended by Haynes manual and Owners Manual)
    Power Steering Fluid: Honda
    Brake Fluid: Honda
    Gas: Shell 87 octane
    03/01/08- 129,000 miles
    10/19/08- 136,000 miles
    Blue 3geez
    10.8.06 Photoshoot
    1.7.07 Photoshoot
    shepherd79's Avatar
    Falling Waters, WV USA
    Re: Fluids Thread
    engine oil: Mobil 10w40 (honda uses mobil oil, don't believe me, got to a dealer and ask for can of motor oil. look at the front label on the bottom. it says MOBIL.) No additives, never found that actually works.
    Coolant: prestone. 70 (prestone)/30 (water) mix.
    Transmission fluid: I have 5 speed so i use mobil 10w40. for auto, i wouldn't use anything but honda ATF.
    Power steering: generic stuff made for HONDA. it will say right on the bottle.
    Brake fluid: generic DOT3 works just fine.
    Gas: which ever is cheaper. ones a month i run seafoam or B12 cleaner to make sure injectors are clean.
    Washer Fluid: what ever is on sale in the summer and RainX in the winter.
    1989 Honda Accord DX (A20A1 carb)
    Chicago, IL
    Re: Fluids Thread
    engine oil: 5W30 Quake State high-mileage
    Coolant: Advance Auto longlife (pre-mixed)
    Transmission fluid: Penzoil Dexron III plus Honda HFM modifier.
    Power steering: Honda PSF sold in Autozone & AdvanceAuto
    Brake fluid: Valvoline Synpower Dot 3&4 premium fluid (much better than normal Dot 3).
    Gas: BP 92
    Washer Fluid: Water during summer, and whatever brand fluid in winter.
    1989 Honda Accord DX Coupe
    A20A1 engine, 165K miles
    Re: Fluids Thread
    Oops...forgot to mention what I actually use lol...anyhoo:
    Engine Oil: Mobil1 Synthetic 5w-30 (this viscocity is in the service manual, as mentioned)
    Tranny: Dexron III whatever brand. If I were rich, I might put synthetic, but nah..lol
    Coolant: Like most, just 50-70/50 with the green stuff.
    Power Steering: Valvoline
    Brake: DOT-3 is all that matters to me.
    Washer: Just the blue stuff. Don't use the bug removing stuff because it can harm your paint job.
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    Re: Fluids Thread
    Must not be anything to talk about if we are discussing what fluids we put in our cars. This belongs in a different forum.
    10/Honda/Ridgeline
    NJ
    Re: Fluids Thread
    Engine Oil: Mobil 7500 Syn Blend 10w-30 (+Engine Restore every other oil change)
    Power Steering fluid: Honda
    Coolant: Prestone + Distilled water
    Brake Fluid: Prestone DOT4
    Washer Fluid: SuperTech
    Transmission fluid: Mobil 5000
    Gas: BP/Sunoco/Mobil 87/89 Octane
    snoopyloopy's Avatar
    Killa Cali
    Re: Fluids Thread
    do you guys have an insights into the mobil one fully synth atf? will it work for our cars? although it is a bit pricey at $7/quart... and if that's not the answer, what's a good atf to use that i can get at an auto store?
    Re: Fluids Thread
    Engine: Mobile One 10w30 Drive Clean 5000 with a Mobile One oil filter.
    Coolant: Prestone, 50% water 50% coolant.
    Transmission: Honda MTF
    Brake Fluid: not sure, never changed
    Power Steering: Honda Power Steering Fluid
    Washer Fluid: Rainx
    carotman's Avatar
    Montreal South Shore
    Re: Fluids Thread
    In the B20A Sedan:
    Engine oil: 5W40 Motul 8100
    Coolant: Honda Brand or Prestone Pre-Mixed
    Transmission fluid: Honda MTF
    Power steering: Honda Brand
    Brake fluid: Motul DOT4
    Gas: Any 91 octane
    In the A20A1 Hatch:
    Engine oil: 5W30 Mobil 1
    Transmission fluid: Honda ATF
    Brake fluid: Regular Kleen-Flo Dot 3
    Gas: Any 87 octane
    In the D15B7 Civic:
    Power steering: N/A
    Gas: Any 87 octane
    Like it's been said before, running water only isn't recommended. You need anti-corrosion protection in the coolant or it will eat the engine block and radiators.
    If you don't want any problem, stick with Honda stuff. It's not more expensive than the other ones out there and will ensure a trouble-free life
    I need these parts!
    Bronx, NY
    Re: Fluids Thread
    I second that question hows the mobil full syntheic enigine oil treating your engines.
    Re: Fluids Thread
    i used castrol...and it just leaked out faster...and at 4 buck a quart...im going back to the regular stuff....now i got to clean my engine bay..cuz its covered in oil.
    carotman's Avatar
    Re: Fluids Thread
    Mobil 1 has been fine so far. I can do more mileage on a single oil change. Sine I do alot of driving, this has been helpful in the last winter. I didn't need to change the oil in mid February and freeze my fingers.
    Some people have experienced problems with full synthetic in their engines but it's only because the engine has a problem in the beginning. If oil is pouring out of the seals, replace the seals. The only seals that are a pain to replace are the rear main seal and the valve seals.
    Anyway, with our old cars, it's normal to do some maintenance here and there. Just think ahead and replace stuff that might be problematic in the future. For example, I changed the T-Belt on the 87 hatch this week. I took the time to replace the front crank seal and the cam seal. They cost only a few bucks and are so easy to replace when the T-Belt is removed. That's the kind of job you don't want to do afterwards. Besides, the oil would ruin the T-Belt and you'd need to replace it again.
    I need these parts!
    LX User azazel_18_2's Avatar
    Feb 2005
    89 Accord LX-i
    Cushing, OK
    Re: Fluids Thread
    Engine Oil: 10W30 Royal Purple Synthetic
    Manual Transmission: Royal Purlpe Manual Transmission Fluid
    Coolant: Typical Green Coolant for use in aluminum
    Used synthetic oil before rebuild and it leaked out all of my seals. After rebuild sythetic is the only way to go. I don't see anywhere it says to use 5W30 in the engine. I see 10W30 or 10W40. My accord had an auto but I changed the fluid and didn't use Honda fluid and within a thousand miles my tranny started slipping. Honda ATF if the only way to go.
    Killa Cali
    Re: Fluids Thread
    Quote Originally Posted by snoopyloopy
    so my question still stands. and what do you guys think of this? one quart mobile 1 + one quart b&m trick shift + one quart of maybe honda hfm modifier?
  1. My 1g Thread
    By 2ndGenGuy in forum 1geez Accords
    Last Post: 11-15-2012, 08:09 AM
  2. 89lx-i tranny/fluids help+misc...
    By MercuryRune in forum 3geez Accords
    Last Post: 09-29-2006, 01:58 PM
  3. Engine treatment fluids
    By Stegge in forum Performance
    Last Post: 05-26-2006, 10:43 AM
VigLink badge
