Ok, here is the story this time:
I can zoom around in my car like normal, it runs and drives as I would expect (other than the battery light coming on every once in a while when I am flooring it for a few seconds or if I am going down a hill on full decel for a while - lol).
However, sometimes I get a CEL (check engine light) - but I am not sure what triggers these lights.
I have checked and once I got 'Engine Coolant Temp Sensor unplugged or defective' which is fine, cause mine is unhooked, and the plug is being jumped by a toggle switch in the cabin.
The other CEL I have found is an EGR Lift Valve code. Now this would be cool except that I am using a B16 intake manifold, which doesn't have provisions for an EGR valve. Also I don't WANT anything to do with EGR. So currently my EGR wiring has been pretty much unplugged, and is dangling in the engine bay.
Now I don't 'mind' having a CEL, but this one presents a problem:
IF, I have a CEL, when I come to a stop, the car tends to want to stumble and die really easily. Unless I am at 2000-2500 rpm or higher, AT ALL TIMES when starting to slip the clutch, the car will die. If I try to do a 1000 or 1500 rpm slip to get the car moving it will die. Now I don't mind killing it, but when it dies like this, it won't start again for about 10-15 minutes.
I am assuming (but haven't been able to check the code that's occuring when this happens) that it's the EGR code that is screwing the car up. However it might be true that when my fan is on, the temperature of the car looks WAY too high and the ECU won't let it start. I just thought of that, and havent tried shutting the fan off before restarting the car.
If the CEL has NOT come on yet, the car will take off normally, and I can start and restart without any trouble at all, so it is definetly related to something that is causing the code.
Any ideas? My first thought was to get a resistor on the egr wiring i have, so that it will simulate a normal value, and keep the ecu happy. for the fan jumper i could do the same thing, so the car sees something like 210 degrees, and thinks to turn on the fans. instead of some wierd signal that it sees when hardwired.![]()
