Page 1 of 3 123 LastLast
Results 1 to 25 of 55
Thread: What Octane Fuel do you run in your 3gee?
    just wondering what octane fuel you guys run?
    I run 89 (In California)
    Re: What Octane Fuel do you run in your 3gee?
    91, its the only 1 we got here, and isnt there already another thread about this? :P
    snoopyloopy's Avatar
    Killa Cali
    california 91 octane from the 76 station on the corner of anderson street and redlands boulevard in loma linda, california.
    i was runnig 91 till i made the trip to maine wich i knocked it down to medium grade to save some cash on the trip, then when i got here it broke down so right now its getting fresh air only lol
    my mom would run 89 on the dx ever since she got it.....later the car did not run right and we would put 91....it did not help...it was all in my mind. anyways...now that i work....i put cheap gas in....87.....i just heard that i should put some seafoam....so it can clear up all that build up...anyways ima go get some tomorrow maybe pick up a claybar kit.and wash it so monkey or legend can make me a sig.
    Quote Originally Posted by snoopyloopy
    its its going to be like that....i fill up in San Mateo...the gas station is called Gas&shop. its on delaware and 4th ave....they have a taco bell real close....btw im hungry...lol...i need some tacos tonight
    LXi User RamThis's Avatar
    N. Richland Hills, Tx
    87 octane. The lower the octane you can run without detonation, the more power you will make. Higher grade gas does not make your car run better unless you have an OBDI or OBDII car with a knock sensor that retards the timing if it senses octane ping. All octane really means is how volatile the gas is, lower octane, more volatile, meaning it will combust sooner than a higher octane fuel will, effectively advancing timing just due to it's easier to ignite nature.
    High compression engines need high octane fuel because it's combustion is easier to control, meaning it wont ignite from just compression and heat alone, the spark of the plug has to be it's source of combustion.
    View my Image Gallery
    1989 Honda Accord LX
    2006 Toyota 4Runner SR5
    1996 Dodge Ram 1500
    2000 Dodge Ram 1500
    MY 3G UPDATE THREAD
    <<<< cali 87
    Quote Originally Posted by RamThis
    just in my defence lol i have bad pinging whenever i give it more then half open, and timeing had been checked over and over, just depends how lean you run aswell wich seemed to work out for me running leaner with more octane, just deffending myself lol
    Killa Cali
    when i switched from 87 to 91, i didn't notice that much of a difference. it wasn't like going from a car limping on 3 cyl to a perfectly purring vtec motor. but it was noticable, mostly in the car running a little smoother. and i also got an ever so slight increase in mpg.
    carotman's Avatar
    Montreal South Shore
    The stock A20A is designed to run on 87 octane. OD, you have 91 there cause they use the RON method calculation. Here, we have RON+MON/2
    I use 87 octane in the A20A and 91 in the B20A.
    I need these parts!
    Idaho
    It's had the same 1/2 tank of 87 gas that it had in April...
    87 ftw!!! no need to spend extra money on octane that the engine doesnt need
    LX User 3ghondaerodeck's Avatar
    1988 Honda Accord Aerodeck 2.0 EX-i
    Gemert, The Netherlands
    I run 95, in Holland we don't go lower, every ones in a while I go with the shell V-power that's 98 (whenever I'm in Germany I go with the german v-power that's 100 101 I think)
    niks nie nooit nie nee
    nothing not never not no
    Banned
    I run 8 oz of Chicken broth with 87
    Quote Originally Posted by GhettoNoodles
    i heard you get like 45mpg with that....and your car smells cleaner...kinda like burning vegi oil on a diesel
    huh? i googled that but didnt really find anything helpfull
    Banned
    nothing like chicken down the carb!
    wikipedia is your friend
    The most common type of octane rating worldwide is the Research Octane Number (RON). RON is determined by running the fuel through a specific test engine with a variable compression ratio under controlled conditions, and comparing these results with those for mixtures of isooctane and n-heptane.
    There is another type of octane rating, called Motor Octane Number (MON) or the aviation lean octane rating, which is a better measure of how the fuel behaves when under load. MON testing uses a similar test engine to that used in RON testing, but with a preheated fuel mixture, a higher engine speed, and variable ignition timing to further stress the fuel's knock resistance. Depending on the composition of the fuel, the MON of a modern gasoline will be about 8 to 10 points lower than the RON. Normally fuel specifications require both a minimum RON and a minimum MON.
    In most countries (including all of Europe and Australia) the "headline" octane that would be shown on the pump is the RON, but in the United States and some other countries the headline number is the average of the RON and the MON, sometimes called the Anti-Knock Index (AKI), Road Octane Number (RdON), Pump Octane Number (PON), or (R+M)/2. Because of the 8 to 10 point difference noted above, this means that the octane in the United States will be about 4 to 5 points lower than the same fuel elsewhere: 87 octane fuel, the "regular" gasoline in the US and Canada, would be 91-95 (regular) in Europe.
    http://en.wikipedia.org/wiki/Octane_rating
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    I run 87 octane. No point in running anything else like RamThis said its just a waste of money to run anything else. Bare in mind if you turbo your motor or whatnot, then 91 would be a good idea... but on a pretty much stock a20 there is absolutely no reason to run anythin more than 87
    87 unless there out then i get 89 if we got 89 in my old accord it got 45mpg but it really stunk and smoged all up in here
    Quote Originally Posted by Hash_man_Se_i
    you guys should send me a few barells(sp?) of 87... lol and heres me thinking i could just water down 91 to a lower octqne :P
    ^ did u see my post? your 91 is our 87
    ergh i just saw it now, i guess i should hit the refresh button before making a post
    your gas is still cheaper than ours though
    carotman's Avatar
    My Owner's manual even says we have to use 91 Reasearch Octane Number in the Accord I guess they didn't know we don't use RON numbers in Canada.
    I need these parts!
  1. Octane
    By Xtreemjedi in forum Performance
    Last Post: 09-04-2006, 07:59 PM
  2. what octane fuel?
    By Ludi Mali in forum 3geez Accords
    Last Post: 10-30-2004, 10:09 PM
  3. Will A Difference Be Felt With 88 or 89 Octane Fuel?
    By MIK3 in forum Classic Honda Community Chat
    Last Post: 06-23-2004, 04:39 PM
  4. 98 octane fuel
    By Toby in forum Performance
    Last Post: 11-28-2002, 10:40 PM
  5. which octane do you use?
    By phatazzDX in forum Classic Honda Community Chat
    Last Post: 08-06-2002, 01:35 PM
