So, I will be working on these now! I'm going to use a small circuit board and cut them to fit inside these housings.
I want to put about 8 5mm leds or 4 10mm leds in each of these housings. The circuit board will be 1 1/4 x 1 3/4 inches.
Too bad this housing is broken. I pulled it out of my box o shit in the garage that I've had for years.
I will only need to use one of those plugs on each set. Good thing is the circuit board will plug into those two prongs with a female end!
