un-fucking-real! Im so jealous.
Many congratulations Ichi! Very righteous build.
Yeah, I wanna share that unreal howl with everyone! I got a K+N short ram and filter from Steve yesterday for free, and now the entire downtown turns to look when she clears her throat. I'd also like to see other people do this swap. (esp keep the EFI or multi-carb)
I'm using the modified crossmember and transmission beam from the 84-85 Accord. I installed it, jacked up the car with it and had a bunch of people jump on it and it didn't flex, so I said OK for now. Eventually going to design a heavy square tube version that uses multiple mounting points, but until then will keep an eye on this one.
Nope, very same one. No discernable smoke at any RPM or load. Does leak oil from the headgasket, but not really much. Everything sounds tight, even though the cams did show some wear. I am having some low RPM issues, it seems to load up when hot unless I drive at WOT everywhere. I bled all the air out of the T-stat housing, and have a new Bosch uni-fit O2 sensor. I wonder if the FPR is bogus or maybe the 1/4 inch fuel return line is causing too much restriction, and loading at idle/cruise? No MIL to speak of, but oil smells slightly of gas.
B18 cams are gonna suck. See if you can get the B20A cams repaired or copied. I'm sure these motors are all about the cams.
Unfortunately this weekend I'm going back to Red Deer, school for 2 months, then life goes on. But we should plan something, I want to come back down after school is finished.
I still get it every time the tach says 7.
Thanks!
i was hoping that motor i sold you wasnt going to be a dud glad its working out for you
I was still having this problem when I parked the car. Does anyone know what it is? I was thinking back the other day that I might have read the timing marks from the B20A flywheel are different to the A20 flywheel I used. Is this true? Really can't remember.
All I know is the car should run idle/part throttle way better than it does, and I'd like to fix it when I get back to it.
set the motor to TDC on the flywhel and have a look at where the crank pulley key is, if its upright i think that its good. or put a screw driver down a spark plug hole haha
are you using the ph3/pj5 and the B20A dizzy and cam sensor?? maybe go get a b20a5 dizzy and cam sensor to rule that out
I'm using the PJ5 you sent and the dist/crank and cam sensor from the B20A I bought from Quebec. I swapped them before I knew about the ignitor problem, and your distributor looked kinda rusty inside. I'm eventually going to go with a new B20A5 distributor but I thought it would run for now on what it has. The cam sensors are identical between B20A and A5, yes?
Edit, the car seems to run best when I push the timing all the way advanced, at least within the limited range offered. It barely runs in the middle/retarded, but improves if pushed ahead.
i guess the cam timing is set correctly?? lol both up things on the cam pulleys are up and the marks on the pulleys all line up together and be in line with the head?
We're wondering about that. We tried a bunch of things, and can't get it perfect. If the exhaust cam is set to flat, the intake came is either slightly ahead, with a bunch of slop in the belt, or obviously trailing by one tooth. With the front of the belt tight and the exhaust cam perfectly flat, the crank is either about 5 deg late, or with one tooth different, 15 deg early. I'm really curious how you guys actually get these to run well?
Still wondering if the MAP or TPS is screwed, given the terrible part throttle stumble and idle issues...
correct my crx may have this problem too lol
having the alternator up front looks pretty cool
mean now for some video please i wanna se how fast this fulla is
also get rid of that black box!
Fuck yes! That engine just looks so natural in there. Should have come that way from the factory!
Your problem is perplexing. Maybe it's a timing issue? The flywheel have the proper timing marks on it? Isn't it an A20 flywheel or some shit? Wonder what the difference in base timing is between A20 and B20A...
Did you try advancing or retarding it just for shits and giggles?
I wonder if the advance/retard in side of the distributor is pooched. I'm gonna replace it with a B20A5 dizie anyways. Also, I wonder if I got the right igniter unit as well? Would it make a difference other than not running? NZ ppl post a pic of yer igniter bocks.
theres no such thing as an advance/retard part in them dizzys, it just tells the ecu when the engines at certain angles and the ecu looks at its map and the vacuum/tps and says lets advance/retard the timing. even tho the engine runs fine their could still be a fuckup somewhere tho eg a dizzy sensor or cam sensor etc, Maybe you should run it on a 1g teg dizzy and cam sensor and rule out ignition being the reason its doing a weird running thing?
