Results 1 to 10 of 10
Thread: easy question
    LX User PearlDrummer00's Avatar
    Dec 2006
    1988 accord LX-i
    easy question
    hoW the heck do i tighten my rear vieW mirror
    Re: easy question
    the bracket? or the ball? i myself have asked this question and the answer was....
    go the the jy and buy a new one...cuz the one you have is probably broken
    SEi User ZackieDarko's Avatar
    Re: easy question
    i have a rear view i'll sell ya! im in auburn
    Nov 2000
    Re: easy question
    I think I know what you are asking. Your mirror moves around at the ball joint too easily, right? I had the same problem. Take the mirror down and look at the joint. You will most likley see several cracks around the perimeter of the "ball." Carefully put some JB Weld into those cracks witha toothpick. Then, after the JB Weld dries, put a few drops of blue Loctite into the joint itself. It will still move around just fine, but this will tighten up the joint nicely.
    Re: easy question
    ooooooooor you could buy one at the jy
    Nov 2000
    Re: easy question
    You could check out a JY, but I have noticed that there are actually several different types depending upon whether or not you have the seatbelt indicator lights up on your ceiling. Most of them will have the same cracks in them. The fix I mentioned is a permanent one and cheap, too!
    Re: easy question
    or get a JDM maplight that also comes with the mirror
    Re: easy question
    Quote Originally Posted by DBMaster
    yeah i noticed that the main difference (at least that i saw) was between hatches/coupes and sedans. the ones in hatches and coupes are smaller and the sedans are bigger. my aftermarket clip on wide mirror would not fit on the fucking sedan one but fit perfect on my coupe one before i broke it
    Dec 2006
    1988 accord LX-i
    Re: easy question
    Yea that helped alot. Later dudes.....: )
    Re: easy question
    was that sarcasm?
  1. how easy is it to......
    By RandyAM in forum 3geez Accords
    Last Post: 12-29-2010, 08:52 PM
  2. Is it this easy?
    By REn0 in forum Performance
    Last Post: 01-17-2007, 12:00 PM
  3. Is It Really This Easy?
    By ezeedee in forum General Engine Swaps
    Last Post: 12-02-2006, 04:53 AM
  4. Easy Fix!
    By BlueBead in forum 3geez Accords
    Last Post: 01-19-2005, 05:44 PM
  5. easy question abt side motor mount
    Last Post: 12-29-2004, 11:50 PM
