OK guys, here's my situation.
I've just changed my timing belt, and the engine still won't run, so I've got some questions. The reason I changed my timing belt was because it appeared that it had stretched and slipped.
First, to find TDC, I lined up "the mark" on the flywheel. Everyone keeps referring to it as "the mark" so I just want to make sure we're all talking about the same thing. On my flywheel, the mark I saw that I assumed was TDC was a white + sign. My Honda Service Manual just says "white mark", so I'm assuming that I was right on. Am I right with this? I also verified that the number 1 cylinder (the one closest to the belts) was at TDC because I had very gently put a small screwdriver in the spark plug hole that I could use to "feel" the position of the piston when it came up to the top. That along with the white + sign on the flywheel seemed to indicate TDC.
Also, I positioned the cam sprocket so the UP arrow was pointing up and the two marks on the opposite sides of the sprocket lined up with the top of the head. Then I put the timing belt on and put everything back together. The belt went on very tightly. To me it seemed that it would be very difficult to get the belt on a tooth or two off because if you keep the cam sprocket in the right position and the flywheel on the TDC mark, then the belt will only go on one way. To have the belt be a tooth or two off would be to move either the camshaft or the crank out of the correct position.
My second question would be regarding the "dot" on the crankshaft gear. The how-to on the site says that the dot on the crankshaft gear is supposed to be in the up position. When I put my crankshaft pulley back on, the dot was not up, but rather it was down at about 5:00. If I would have turned the crankshaft to where the dot was up, then I would no longer have the white + mark lined up indicating TDC. It seems here that I can't have the crank in a position where the dot is up AND the white + sign on the flywheel is lined up with the mark. What I'm wondering is if the white + sign on the flywheel is TDC and it is lined up with the mark, then what difference does it make where the dot is on the crankshaft gear? What am I missing here? Thanks for your help.
