How do you remove the front turn signals on an 89 SE-i? The manual shows screws in the front of the turn signals but they do not have them. I assume you need to remove the underside covers and pull them out from inside the bumper.
are u talking corner or bumper
sounds like the bumper ones
what if you had fogs there?
You could just unplug the fogs. Or do what I had to do since my holes are covered up by my kit. I had to take the whole bumper cover off just to have access to the screws that hold the lights in.Originally Posted by sds
03/01/08- 129,000 miles
10/19/08- 136,000 miles
Blue 3geez
10.8.06 Photoshoot
1.7.07 Photoshoot
Thanks guys. that's what I needed.
yup its easy once you know how to take them out.
i had fogs there, its a pain in the ass to get them out, especially if you're sitting on sharp stonesOriginally Posted by sds
Well I got the turn signals cleared by using a dremel and a cutting bit from a rotozip used for drywall board and wood. I don't recommend this method unless you are good at using this setup. I just cut the amber lens sides and bottom in half then pulled it out. I used my air compressor to blow out the cuttings after that. It took me about 20 minutes per turn signal. I am putting the 3watt LED bulbs in place of the original type.
